SHO Smooth
DDakRT
Mississauga, Ont, Canada
well cause we get to see old threads again, a lot of new people prolly never seen it before
I've seen it before and I enjoyed looking at the pics again
thanks for reviving this old thread!
stfu everyone else, if you don't like posts and reading stuff, then why are you on a forum?
Is there something wrong with you? You thanked Sam, and then made that post? :nuts:
matasho
bigshotsho93
Beloit Wisconsin
ok- the 1/4 window comes out by removing the interior trim and using a 10mm socket. theres some studs on the window and if you just take the nuts off and push the window out. its got some sticky/nasty sealant in there but it comes off. as for the side windows the window has to be the first thing to take out, drill out the big rivets that hold window to the regulator and turn the window sideways and lift it out. the window track comes out easy just pull off the door panel and take off the 10mm bolts and pull the window track out. then you have to drill out the rivets that hold the window trim on to the car. the window trim is the part with the chrome in it.
does that clear it up.
matasho
bigshotsho93
Beloit Wisconsin
so im putting a custom spoiler on my car now and a stripe down the middle. i would like to see some stripes on shos. mine is going to be on the hood, decklid, and spoiler. its going to be on the cowl as wide as the raised part of the hood and have a n 1/8'' pinstripe an 1/8'' away from the stripe around the stripe. and on the decklid, spoiler it will be as wide as it is on the hood. and it will end on the front of the hood about an inch from the edge and on the decklid about an inch from the edge. but it will run off the end on the back of the hood and run off the edge of the front of the decklid. kinda like a muscle car.
any thoughts..................
