TREpaNaTion
Local Metal SHO
I have a Black 93 ATX 3.2 SHO.
Intro to the car
I recently bought this car (for $200) about 7 months ago and have been working on bringing it back to life after a Oil Pump failure. (results a blown motor) I got the car home and was looking around at it more in depth checking everything else out. Its in mint condition other then the fact that a rod blew out the side of the oil pan.
My father and I have over the time of purchasing the car. Taken out the old motor and stripped all the good parts off of it. Taking multiple picture of the connectors and placement of everything during removal.
We did some major searching around for a new motor through multiple junkyards and such. I came across one with 87k at a local junkyard for 350 dollars. They were asking 450 but we talked them down because of a few missing parts. (thankfully we have the parts to replace them) We have ripped the Intake off of the motor and disassembled it. Took the Old Valve covers from the other motor after closely checking them and had them powder coated for $130 in Black and Red (Valve Covers and Intake).
We Pulled the exhaust Manifolds because the gaskets were shot on them and cleaned them out. Pulled the water Pump and put the one from the other motor to put in after Painting it (black) cause it was only 150 miles old. Pulled the Pulleys (not the timing ones) to paint them up as well.
I Got all new gaskets (intake, exhaust, water pump, etc..)
Now here is where my questions lay.
How do I go about polishing up the Intake and the cross overs or clean them up with out damaging them myself?
** Note ** I've never done this before.
I have also been told then when placing the Valve Covers back on with the new gaskets that they have to be tightened in a specific sequence to certain torques. What, if any is that specific information that I need to do so? Does anyone have a guide that would possibly explain this for me?
Is there certain Spark Plugs when I put new one's in that work best for this car? ( I am planning on new plug wires as well as it only seems right since the motor is out of th car and I wont have to deal with tight confined spaces as to when the motor is in the car.)
Is there any other things that I should get new before putting this all back together? ( I have the motor covered with a tarp in the garage to prevent any dust or dirt from getting inside the openings and such as well)
Do I have to replace the rubber seals where the crossovers mount up to the butterlies, or can I use the old ones?
I just want to make sure that I cover everything before I put it back in to assure that everything is assembled the correct way so that I don't get it in the car and everything hooked back up and have to tear it all back apart.
Sorry for such a long winded post and all the questions. I tried doing a search for most but Dial up is limiting me for time and I do apologize for this. I hope to possibly have the car going in the next 2 months if I can so that I can start some work on my other SHO that needs some simple but time consuming things done. Thank you in advanced for even just reading this and for the help if you have anything for me.
Intro to the car
) for torque values and a bunch of other useful info.
