89 florida car
oldyak
memphis,tn
Sun damage amazing!!!
rear quarter window plastic molding is falling apart.
how hard to replace?
jelloslug
Digital
Greenville, SC
It's built into the glass. You either have to replace the quarter window ($800 from Ford or $500 aftermarket) or sand it and fill it (or just paint it).
jelloslug
Digital
Greenville, SC
Have you ever tried to remove a 1st gen 1/4 window? Also, I have never seen a decent on in a junkyard......
oldyak
memphis,tn
I kind figured It would be a problem....the plastic is complete but is pitted like nothing I`ve seen...I didnt think plastic would do that.
But I can use spot puddy to fill and repaint.
Jelloslug,
you have been a big help as of late..
are you the "bodywork guru" of the forum???
thanks
oldyak
jelloslug
Digital
Greenville, SC
Jelloslug,
thanks
oldyak
Well, I would not call myself a "bodywork guru"; there are many other here that know much more about bodywork and painting than I. I can also tell you that using spot putty (not bondo) does not work well for filling the roughness on the 1/4 window trim. It will crack out and look like crap in no time. Others have put several layers of trim paint and then sanded between coats. I am going to try some of the 2 part clay like epoxy on my next attempt.
oldyak
memphis,tn
I guess I will try the multiple coats of trim paint first...
It is nice to know that I am not the first with this issue.
the reason I really don't want to do a 2-part is that I am afraid of scratching the surrounding paint or glass...
thanks!
oldyak
