How do you guys clean!?@/?
bigLSHO
PA
Your intake properly. Im talkin all the carbon build up in the runners because i know my old ones have a good amount....I want them spotless. not sure if the ones on the car are as bad but im sure they cant be too much better. I figure ill finish painting this intake after i clean it and clean up the engine bay a little. But what should i do...soak them in degreaser...carbon cleaner...just say F it and work hard and get a couple hundred together and have them ported (i wish it were that easy!)
Ishodu
Non chlorinated CRC brakleen (green can) It will take it off and it will be as clean as the day it was made.
bigLSHO
PA
thanks a lot...hopefully ill be able to do that soon
Bizzy
Berryman's Chemtool is the stuff I use. Works like a dream. :thumb:
bigLSHO
PA
Thanks..ill have to do some shoping. And its ok if the paint comes off...needs redone anyway. Ya know? spare intake has been handled like one so the paint is chipped...sexy color scheme tho. dont know if it will work on the white sho but i might try anyway
http://www.cardomain.com/member_pag...images/2/web/830000-830999/830801_14_full.jpg
This doesnt have the butterflys in it but they are "semi polished" looks good tho, unless your like 3 inches away!
RustyNutz
SHO Monkey
Burque
I'm a fan of brake cleaner. Only for price. The three intake cleansings i have done were always carb cleaner... the crazy part is "hearing" the difference... my motor actually changed pitches as the intake is 50% of the sound the car makes.. my opinion with 4-5 millimeters of PCV diameter buildup. I should hang a disclaimer about the sound... it was my own opinion.
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
I used berrymans and baby bottle brushes, but I've seen a lot faster results with Easy Off oven cleaner. If I do it again, I'm cleaning the oven.. :)
frosho
WOLFMAN
Tyngsboro, MA
i used brake cleaner as well and i definitely noticed a change in intake sound afterwards. louder and deeper.
LJRuddy
Pop lock n drop
Poaceae fields
Yea buy several bottles of that chemtool and spray it into the intake so that it puddles up. Then take a wire brush (or dremel with a soft brush attachment) and grind those hard carbon deposits down. The oily coating that covers the rest of the intake will come off just by spraying it down with the chemtool. Let dry in the sun for a few minutes and reinstall :)
Dedragonknight
CPS Porter
Chicago
pffft. sonic cleaning and porting works well :)
nah i just use a ton of brake clean and carb cleaner usually, and some elbow grease. Sonic cleaning is too expensive for what I do 99% of the time
F-22 Raptor SHO
7015 feet above Sea Level
PLUS:
EQUALS:
NOTICE: The reader of this message assumes all responsibility for what this intake cleaning method will do to the relationship you have with your wife, gf, mom, or live in partner. Would recommend you do this at night....when everyone is in bed.
I've found a foaming citrus cleaners work good. Anymore I shy away from the cancer in a can brake cleaner/chemtool stuff.
Citral degreaser 2
itwonder
VA
Is it possible to do a decent job of cleaning the intake without completely disassembling it? Any risk to the butterfly valves from solvents/detergents?
n8rsk8r
Hey Where's my post?
Olathe, Kansas
if you don't care about the paint use the paint stripper, that stuff will clean the crud right outta it!.... and off it too :nut:
