ilSHOu
thanks for the pics ishodu!
I just ordered used gen3 knuckles with hubs from eBay. I'm debating whether or not I should get the control arms too or just find a boneyard to pull a subframe w/ control arms from.
I'll use the trans mount from my old subframe; I just need a SARC box, associated wiring, ABS sensors, and PS steering lines with adapters. Oh yeah, I'll also need to figure out what I'm doing with brakes as the wilwoods aren't going to fit "as-is".
JEM-you're planning on using the gen1 lines with adapters on them correct? Can you elaborate on what size fittings are needed and any special angles?
I'll know somewhat more on the pressure line soon, maybe tonight. I suspect most folks who've done the conversion thus far have gotten too clever at the rack end, and we'll see if using the Gen 3 firewall boot and pressure-hose mounting bracket simplify reuse of the stock Gen 3 rack end, but I'm still waiting for some bits to get here and I'm going to be out of town part of this coming week.
If so, then it's just cutting the pump hard-line end off a Gen 1 hose, the rack hard-line end off a Gen 3 hose, figuring how they 'clock' relative to one another once installed, then trotting down to the local hydraulic shop and having 'em put two feet of hose in between.
96-99 knuckles are all the same and interchangeable
96 & 97 control arms are the same (are they aluminum too?) and can only be used on 96 & 97 subframes?
98 & 99 control arms are the same and can only be used on 98 & 99 subframes? - per Paul, they use a larger front bushing bolt
2000+ control arms are the same as the 98 & 99 arms but are steel?
2000+ knuckles are different (tie rod positioning - per Paul)
Which subframes (year) are people using for this conversion and does anyone know the differences between the years?
Another oddity is the ball joint mount. My replacement OEM ones from 2001 did not have snap rings to retain them unlike the latter year ones.
really? that is really weird. That C-clip is a major safety feature. In providing quality services to a major Ford OEM suspension supplier, a missing C-clip is a major major issue....
Is there a retaining nut inside the subframe rail for the vertical bolt that holds the control arms in or does this bolt pass through the entire the subframe?
Thanks!
Ian
Don't forget the split collars on the sway bar.
That video makes me want to take a year off from real-life and build a V8 MTX. Who cares if it's only 15 more hp, it sounds like 100.
