Power Surge
Doug, were does that other hose lead to in this picture?
On the intake side, under the charge pipe.
Bypass valve.
I've set it to about 9psi as a cap. Should still put 325 to the tires and get 25mpg.
400hp and 32mpg is possible![]()
for the charge pipe across the engine bay ....assuming the charge pipe is 2.5"
-get a piece of 3" pipe
-get a pair of 2.5" to 3" silicone couplers
-get some spare hose (radiator or silicone coupler.. anything close to pipe size)
- drill 2 small holes in the 3" pipe, one top left, one bottom right (as installed on car
- cut 2 narrow sections of radiator hose, epxy to inside ends of 3", but dont block the holes .... these are just to gap the 3" away from the 2.5"
- assemble 3" pipe and couplers over 2.5" pipe, leaving drilled holes exposed
- slowly fill the space between the 2 pipes with pure argon
-when full, slide couplers towards each other to cover drilled holes, install clamps
and now your charge pipe wont suck up ANY heat in the straight section, because argon is a GREAT insulator ... its what they use in double pane windows
Quick question ...
I have a WG with a 10.29(.7Bar) Spring and a BOV with a 9PSI Spring. I will be getting a Apexi AVCR boost controller.
Q: If i need to surpass the boost limit of the springs will the boost controller be able to control that regardless of spring pressure?
i broke somedude's bumper the day i stood on it to tie the hood up out of the way
you never told meas soon as you cut into that plastic bumper it will become worthless in a collision. ****, its ALREADY mostly worthless in a collision
if you realy want a bumper on the car, have one bent out of 1 1/2 steel tubing, and tuck it up against the cover
