Tune Issues
Grand Rapids, Michigan
Recently installed GH ao tune with dp, did my plugs, thermostat, and 3 bar. Tune loaded with advance trac and collision warning off, started up and sounded super weird, had no power or shifts. Reflashed, worked, and was running normal. took it for a 10 mile drive to see if the shifts would smooth out. Got home, turned it off and back on, same thing happened. I repeated this process, the second time letting it idle when there were no lights, etc. Still did the same thing after everytime I tried to restart it. Flashed it back to stock no issue. Any idea what happened? I had codes p0106, p2196, p2198. Did I get the wrong map sensor? IMG 0311
IMG 0308
IMG 0312
D7ad9b83648b7da8330468668b306274
If the one on before my throttle body is a 3 bar, is the distinction between a 2 bar and a 3 bar the square on the left side of the sensor?
South Carolina
Recently installed GH ao tune with dp, did my plugs, thermostat, and 3 bar. Tune loaded with advance trac and collision warning off, started up and sounded super weird, had no power or shifts. Reflashed, worked, and was running normal. took it for a 10 mile drive to see if the shifts would smooth out. Got home, turned it off and back on, same thing happened. I repeated this process, the second time letting it idle when there were no lights, etc. Still did the same thing after everytime I tried to restart it. Flashed it back to stock no issue. Any idea what happened? I had codes p0106, p2196, p2198. Did I get the wrong map sensor? View attachment 96445
Im pretty sure this is a factory 2 bar sensor. You need the CX2594 from rock auto.
Cincinnati,OH
The map sensor on the tube before the throttle body is a 2.5 bar map sensor. It can be used but it’s not a 3 bar map sensor. And you have to be specific about these things to your tuner.
Life has got in the way for me haha. Hockey season is wrapping up, playoffs next weekend. I’ll post results in a few weeks when I get the time away from school.
BradM
Your original picture of the suspect "3 bar map sensor" doesn't look like an OEM part to me. The markings don't look right.
Following up, took me a bit longer than expected. Re uploaded the tune and put the new map sensor on. Drives like a charm. No more sputtering or hard shifting. Thank you all for the help!
Good to hear.
ShatteredMJ
Far away from the US
While on this topic and after reading @Sleeper.Solutions86 comment I realize I may have messed up. I always thought the pre-throttle TIP sensor is a 3 bar. I have used it as a rescue sensor when my MAP sensor failed. Since then I’ve been using them interchangeably, new sensor goes to the manifold and old one to throttle inlet.
Now I realize this might be the source of some weird knock issues I get. Probably wrong TIP readings. Anyone know the correct part number for the TIP sensor?
Continuing these issues. Shifting smoothed out over the next 100 miles. I’ve tried maybe 3-4 hard pulls from a standstill, none brake boosted. Twice I’ve missed 2nd, then shifted to 3rd and let off the throttle. One other time it grabbed, not on full throttle. Pretty bad shudder. I emailed Matt and he said to make sure I was half a qt above full of trans fluid at hot idle. I obliged and have yet to take off from a stand still, but from a roll it has gotten better, it will catch and shift hard but not shudder, or it will miss. Everything else shifts perfect. Should I try a fluid drain and fill? Trans parts wearing down? I’m at 120k, I’ve drained and filled the fluid 3 times since I got it at 96k. Changed at 100k, 105k, and 110k. No issues on the stock tune. Any input would be amazing.
Cincinnati,OH
You will not be able to brake boost a GH tune to my knowledge from a roll. Because the brake threshold timer isn’t adjusted from the factory 3 second delay.
