If it started and you can drive it without any issues, then it was the sensor. You can search for Code 214 on this forum. There are a lot of posts on what is happening. If your cam sensor failed, it could be due to oil leaking from the cam seal. If so, you want to replace that as well since that is probably what caused the sensor to fail. There are posts on how to replace it as well. It's a common problem.
The camshaft seals on the SHO tend to fail and leak oil. Often times the camshaft sensor will get oil in it and fail when the rear camseal leaks, tbut there are also seals behind each of the two timing sprockets (three seals total on an engine). We found a heavy duty rubberized seal almost...
shosource.com
shosource.com
It started right up. Which raises the question "why do I need a camshaft sensor?" Is there any special procedure when installing a new sensor to get it to communicate with the ECM? Thanks again for your help.
