It's my daily so I'm going to get an extra set of heads and do all the seals. I also am getting a lot of start-up smoke so I'm pretty sure this thing is leaking like a sieve.Failed/improperly installed cam seal is the #1 reason that the cam sensor starts acting up.
I recommend doing valve cover gaskets at the same time. That way you can pull the cam cap and verify that the seal is seated properly. Since I started doing it that way I have yet to have a seal prematurely fail.
-Chad
I had alot of extra stuff but not heads. That's extra. Approved!It's my daily so I'm going to get an extra set of heads and do all the seals. I also am getting a lot of start-up smoke so I'm pretty sure this thing is leaking like a sieve.
