loganbro28
SOLVED: The issue was a faulty Crank Position Sensor.
So this issue has been happening for a few weeks now. I go to show my friends the car and it won’t start. I wiggle around the CCM because I took it off to crank the engine before I fired it up for the first time after changing rod bearings to get some oil on the engine. Then it fired up. Ok thought I solved it..
Then it does it again for my brother so I told him to clean it. Keeps dying… we tightened it down. Cleaned and re tightened the TPS.. ot fired up! Then died after like 10 minutes of idle.
I noticed the idle air tubing is pretty burned through in the engine bay. Could that be the issue? The car runs great when it starts up and drives but now it won’t start!
It starts giving issues after its warmed up a little bit then parked and tried to start up again.
Wondering what I should do next…
