Trying to slide in snow
gagebruv
Iowa
I'm not sure, it's been a while since I've used forscan, and I have a 2018, so I wouldn't be much help anyway.
Sent from my SM-S918U using Tapatalk
I gave up on the FORScan and took my car out for a drive. I did a couple second gear pulls and my abs light came on and disabled traction and stability weirdly enough so I guess it worked out. No idea what caused it. No check engine light either.
Nova
US
Congratulations....? I guess lol now slide her around!
gagebruv
Iowa
Stability made no difference sadly. Seems as though this car can’t slide unless it’s on ice. Pretty disappointing going from my STI to this. Though I suspected this would be the case with haldex awd.
Ta2dResqr
Central Ohio
I don’t see it. It takes me to motorcraft where I put in the VIN.
As-Built data is specific to each car. Your As-Built data is different then another 2010. Put in your VIN, put in the security check, then it will give you the files.
gagebruv
Iowa
Ah okay, I’ll try it later today , thanks for this info.
FREAK_SHO
Wisconsin
Takes some practice. I have a non PP '15 and can get it to step out in the snow. You can even get it to "drift" through the corners. Get it in an empty snow covered parking lot and practice. True, not Subbie capable, had an '02 bug eye, but it can be done.
gagebruv
Iowa
I’ve gotten it sideways a couple times but it only seems to do it on super slick surfaces, otherwise the front end just plows. With stability control off I couldn’t get it to power through to do a donut. When I see videos of them sliding it looks easy from the outside. Makes me question if my awd isn’t fully working or if my skill is lacking.
76FoMoCo
Nampa, ID
I have a 17 non pp and a 13 pp. The 17 with the TCS off is not the same for power to the back wheels. Even when I tuned it doesn't seem like it sends the same power out back as the 13
gagebruv
Iowa
Interesting, I can’t imagine that the pp would make a difference with the awd power distribution. Unless they changed the haldex system in later year models. I know ford did quite a few tweaks to the SHO platform over the years.
Florida
Bare in mind the non pps have longer legs, the gear ratio is lower in the pp cars. Even turning off all the nannies it's still front wheel biased and heavy, in absence of power to break the rear wheels you need inertia and maybe some harder compound tires to slide. Slick surface will get you sideways but probably be difficult to control at speed. The gear ratio and baby sitters I think are the real issue though.
gagebruv
Iowa
I could see different tires making a difference, I’ve had the car for a month and the previous owner put some weird cheap tires on the car. For some reason they also put a single Bridgestone tire on the rear passenger side. As far as gearing I tried some higher speed flicks in a parking lot and still got front end plow, so the car maybe too gripped up.
Florida
It's sketchy but I'm not giving up lol. Push the ebrake all the way down, push to unlock and don't let it come back up and boom, drift brake. Buddy showed me that trick on a grand prix gtp so I don't know how it'll work in the taurus, worth a shot?
gagebruv
Iowa
I’ve considered that, but I’m worried I’ll break something. My dad has told me stories of parking brakes getting stuck due to lack of use. I’ve also never used a pedal e brake. I may try it, but my area is in heat wave so I’ll have to wait for the snow to come back.
Florida
I won't talk you in to it and I hear you on the afraid of breaking something but I will say I did it on dry with an old 93 t bird (rwd, irs) and didn't hurt it. The way our ebrakes work is ideal for the job and I believe the new mustangs electric drift brake uses similar calipers. The piston "screws" inside the assembly, my advice if you try it is to check your cables and grease them if you're worried about it and then check the function, do a few slow runs see how it feels. With the pedal on the unlock swing it should move freely to allow for feathering, lift on the throttle before you brake so you're not fighting the drivetrain.
