Intake Manifold upgrades?
2014RedBull
Cambridge, MA
Crickets, crickets, crickets. I grab another intake manifold. I was planning on send it to Super Six when I discovered Wilson Manifolds. Maybe I should send it to them and see what they can do with it. (I was thinking plumb it for a 50-75hp scramble niitrous kit. I'm not convinced on meth). I was also going to send them my GIGs performance 73mm TB to port match the two pieces. Nerxt issue I think is the IC to TB pipe. (Daily Driver in the world of everything running around. An EcoBoost Escape made me work for it. Saw a Hellcat Charger or maybe something else. It was going in a different direction. I also want to work on my roll racing program). Thanks!
802SHO
Boost > VE, MBT, Cams
Essex Junction Vermont
Not convinced on meth? I bet you haven’t found or read anything about using 100% meth injection and it DIDNT work. Good luck with your project.
I removed my GIGS TB - it was causing airflow issues which caused slight pauses in acceleration, I needed to remove it and go back to stock. Brad couldn't fix it snd I tried resetting the TB position sensor 3 times. It is garbage and recommend going back to stock. The vendor calculated 73 by the elongated butterfly. He doesn't remove material from the body itself. If you look closely there isn't anymore you could bore.
Just my humble advice, it's a gimmick and can cause issue. I herald cleaning up and reducing turbulence in the intake over the stock crapola.
Just my suggestion.
I agree - I haven't run meth, but meth is safer than nitrous. Forced induction pushes the limits of our engine. Get bigger turbos and run hard pipes if you haven't already.
2014RedBull
Cambridge, MA
I'll try a Mustang TB along with the ECO PP kit. Have Super Six port the intake manifold. (I hope I get a GH IC when they are available again). I'm getting the AO 93 tune soon. E30 tune, larger turbos, PPE catted downpipes and exhaust in the Spring.
