Blown turbos?
Mannywrks
Colorado
I recently got a 2011 sho and it was working like a dream but today on my way to work i lost power from both of them out of nowhere, no strange noises nor smoke, just complete silence. can anyone give me tips before i start pulling stuff out, i’d appreciate it!
bpd1151
Lurking Around
SHOcago 'Burbs
I'd start with checking for any tears/rips in the orange silicone sleeve of each factory Electric Blow Off Valves to start with. Then go from there.
Sent from my SM-N986U1 using Tapatalk
ridered74
Pull the engine cover off, a little further back from the front driver side spark plug is a little black hose that is known to blow off the charge pipe. If that happened to yours, put a clamp on it after you reattach it.
Mannywrks
Colorado
there seems to be oil in the bov and intake, i’ve never owned a turbo car so idk what it could be
76FoMoCo
Nampa, ID
normal to have some oil in them. Have you check the wastegate rod at the turbo? there is a small E clip holding it on and have been known to come off. Also did you locate the hose with the zip tie in the pitcher above?
Mannywrks
Colorado
Yea the hoses were just a lil loose and i zip tied those but while looking for the E clip i saw this on my the turbo near the passenger wheel
