1992 transmission issues
Bryan
What do you get when a deer & SHO cross at 45mph?
Morgantown PA
Hey guys so thing is on my 92 SHO when depressing the clutch to change gears it makes a somewhat wizzing sound. Clutch shifts fine and all. No problems with engagement or the clutch itself. I am wondering does this possibly sound maybe like the clutch isn't fully disengaging? could it possibly be a stretched shift cable?
Greg Corcoran
Denver metro area
If it starts just after clutch pedal is on the way down I would vote for throwout bearing if all else is shifting normally. I'd just live with it until it got much worse.
Bryan
Morgantown PA
Ah okay. Yeah its just a little wizzing sound. For future reference is there parts available to fix the transmission?
I think some of the synchros may be hard to find. I would get a used unit if mine was broken. I agree with TOB for first guess. If that is correct it is wearing with noticeable noise. You will probably have to dig into it at some point.
Bryan
Morgantown PA
Okay then I will begin hunting around for parts. However I don't thing the synchros are bad as I have no trouble shifting gears. The go in like butter.
If you have time and space you might want to open the area and get a look at the tob, pp, and clutch. I mean there used to be a cable tightening mechanism that often jammed up or people didn't use to adjust the engagement with wear. I haven't used one in a long time. My cars were 2nd vehicles with alot less miles than the ones I bought when I was younger and used as daily drivers.
