Son just got 95 SHO with 62k miles on it.
95Sho60k
Columbia Falls, MT
Just bought for my son yesterday a 1995 SHO with 62k original miles on it. Runs and drives amazing. He stated on the way to school this morning there was a burning smell from the AC like wires where heating up and what not. Once he powered the AC/Heater off it quit so i am guessing improper ground. I will post pics when he gets home :)
Silver in Color
Grey Interior
Manuel Trans
He is in love with this car.
Also is there anyway to do after market headlamps for better lighting on the vehicle?
Post some pics! Welcome to the SHO.
zoomlater
Seattle, WA
Welcome! I was at a Pull a Part this past weekend and on 92 MTX they had there, I saw the previous owner had aftermarket wiring going to both headlights. Each had a small square/flat device in the wiring going to the headlight bulb.
Ta2dResqr
Central Ohio
Headlamp Assembly or Headlight Bulb?
That age, I am guessing they are yellowed or pitted and could benefit from new clean housings. Bulb, there are a ton of choices. I would stay away from "blue", "hid look", etc and over wattage bulbs. I would look at Sylvania SilverStar Ultra, Phillips NightGuide Platinum, or similar. It should be 9007 or HB5 (same part). I personally don't recommend HID or LED without retrofitting the housings.
Another thing you can do is rewire the system. Check out Daniel Stern Lighting for a more in depth article.https://www.danielsternlighting.com/tech/relays/relays.html 0.5v drop across wiring, switches, relays, connectors, etc can easily be over 200 lumen lost at the light source.
Ta2dResqr
Central Ohio
Welcome! I was at a Pull a Part this past weekend and on 92 MTX they had there, I saw the previous owner had aftermarket wiring going to both headlights. Each had a small square device in the wiring going to the headlight bulb.
Sounds like an HID kit
Toolman
Boost it!
Grand Lake, Oklahoma, USA
Welcome.
You might be able to find Dave W. who built my lights.
