Airbag code 10
blk\blk90
TX
My light has been flashing 10 since I bought the car. Now, with the thermal fuse blown, is it safe to just replace the module, or will it just b l o w again? I looked on car-part.com and it looks like they have quite a few listed from various 90s fords, most around $50. I don't want to throw one in just for it to pop again, but I'm not sure what would cause it to short.
Screenshot 20211102 081250 Adblock Browser
Edit: what's up with the sensoring on here? That's a bit much....
Airborne
If you install a functioning module, yes, it will pop the thermal fuse, but not right away. Put the functioning airbag module in and turn the key on, quickly count/read the flassing code number. That number will be the main issue with the airbag system, fix that issue and you will be good. Do not turn the key on too many times before fixing the issue or the system will **** the thermal fuse again, that is the airbags systems safety default.
I have fixed this about a half dozen times, the majority of times it has been a crash sensor. One time i got a code for drivers airbag fault. I replaced the airbag and clockspring. I knew it was either the airbag or the clockspring, i just replaced both to keep from popping the thermal fuse trying to pinpoint.
blk\blk90
TX
Cool. I'll call the yard and get one coming. Are crash sensors a common part?
Airborne
Obsolete like the module. I found my last one on ebay NOS, resonable price too.
blk\blk90
TX
Called my local salvage yard and they have a few 89-91 taurii there. 5-10 bucks for the abs module. I figure I'll grab 2 if I can, and the crash sensors if they're easily accessible and the same between the regular taurus and SHO.
FastCAD
Miami, Florida
unplug the module and disconnect the air-bag light behind the knee plate right of the steering column and be done with it. bag will be disarmed and no light, clicks, chirps or beeps. you can save $$$ and your sanity trying to find a fix.
Airborne
The ones i had to replace are easy to get to. A couple are up front near the radiator. The passenger one is by the parking brake lever, i think i had to remove some trim pieces.
blk\blk90
TX
Went to the junkyard and found a 1st gen sable. Pulled the srs module and put it in mine. Still flashing 10. I think I'll just leave the module out and pull the bulb.
1636238862007544119414565201275616362388930253816805238519110962
Also, anyone have a passenger air vent they'll sell me?
Airborne
Should have posted this earlier. I did this one time after installing a used module that also had a blown thermal fuse. Seems intimidating, and i was surprised it worked. Take your time and have the proper tools. Heat sink and solder vacuum is needed. Found tools and capacitors from the last repair job. I did repace the capacitors, as the right up said, hoping that was the only issue and the cause, like the write up. However, my issue was a crash sensor. So, like i wrote before, be prepared to count flashes and turn off ignition before the system blows the thermal fuse as designed.
