Ok let's do this in a tranny thread, I'm game.
Step 1, find car. Mines very dirty in a garage and hasn't been driven since who knows when.
Ok looking at back seat, that's where my dag gum ratchet strap went.
Under the front part on the middle of both driver side rear and passenger side rear are little plastic slide clip things. Push them to the side while pulling up the front. Do the same on the other side
Hard to see but the front is jacked up a bit from it being unhooked. This is good.
Tricky part for first time. With front unlatched, push seat to the back while picking up on the back and it will unlatch the back. Do to the other side the same
Then pick up on the whole seat and tilt it forward. Remember to shove the seat belts down through it. My 15 has 3 plugs. Big one and 2 small green connectors hidden in the sides of the back part of the seat
Unplug the 3 plugs. They were actually simple for connectors
And then nice clean leather seat can come right out and on a dirty garage floor.
And then clean up a little bit while its out and find some missing stuff and then you got weight reduction.
Back parts can fold down nearly flat, I didn't because I'm young and dumb but put something down so the metal dosnt mess up or tear the leather backs. Remove the headrests if you'd like. Back seats also unbolt from the bottom that you can see now when looking under them
And except for the tunnel having a narrow hole it should help a bit for holding more cargo
