Drivetrain strength
Michigan-SHO
Michigan
Mmmmmm...... now that right there's a very hot, sexy, tempting offer.
Easy there tiger. RAWR
My goodness...... with those words you are going to get everyone aroused
Michigan-SHO
Michigan
Make an adapter plate for the trans and swap the total engine. Cut out or eliminate anything that doesn't fit.
I had a 377 in a Chevy s10 that basically was installed using welders, torches, and sledgehammers.
My biggest issue is the transverse and longitudinal mounting. So much would have to be customized, the headers the intake the turbos the engine mounts. It gives me anxiety just thinking about it. Hahahahaha
High on Ethanol
Just Ain't Care
USA
So...now im thinking why doesn't anyone work on the efficiency of the 1960s gen5 SHO? Active shutters? Reduce drivetrain loss? Reduce frontal drag?
High on Ethanol
Just Ain't Care
USA
Not as much as you would think. Get @skyshadow07 to cut your exhaust in for you. Route the intake to your gt500 hood. Get AD-mounts LLC to fab you some engine mounts. Anything else?
Michigan-SHO
Michigan
Just needs an adapter plate like ford guys use to run gm transmissions and vice versa.
If it’s that easy then all we need is a stock Limited/Raptor motor and GH Turbos with an adapter plate and a Tune!!
After that, the sky’s the limit, shit, no it’s not,
THE TRANSMISSIONS THE LIMIT!!
High on Ethanol
Just Ain't Care
USA
Nailed it. Lol if you research like I do, it can be done....but at what cost? The motor alone will cost you 10k~ish
Frostbrosracing
Austin, TX
So you hate 1975-1988. Careful, that’s about everyone here lol
But didn't the original Mach 1 phase out in 1973 to give was to the Mustang II? And the fox body started in 1979. So, technically the dark ages were only 1974-1978. Also known as Gerald Ford's presidency.
Michigan-SHO
Michigan
Lipstick on a pig
shobroooo
