Drivetrain strength
FiveLeeter918
Ortiz Performance Sales
Tulsa, OK
Good read, and great information from all except that "We can't run E85 comment..." lol
I've yet to run actual E85, but the car handles pump E74 just fine with 2900 psi fuel pressure at 18 psi and 28 degrees of spark :)
Ryan Selcer
Colorado
Do all the fuel lines have to be replaced?
High on Ethanol
Just Ain't Care
USA
Can you share datalog of load vs lambda vs fuel pressure up to redline?
Ecoboost_xsport
Sacramento, CA
Yes, with the XDI-35 and the DW300c, according to Matt at GH, it struggled to provide enough fuel when running full e85. It sounded like it worked, but it was right there on the edge. I've got the XDI-60, DW300c, and a set of XDI +50% injectors, so I know fuel supply will be an issue once I get this thing finished. One of the reasons I've been working on that surge tank project. Not much progress on that front yet as I've had a ton of things going on and it's not as easy as it sounds since our vehicles utilize PWM returnless fuel systems. I'd like to keep that functionality but I don't think the stock fuel pump control module can handle the current needed to run multiple pumps in a surge tank setup. Which means go to a bigger module, but the stock module receives event notifications from the PCM that I'm not sure how an aftermarket one will respond. So one answer is using Solid State Relays, but then you run into cost issues with higher resolution relays that are usually needed to control high output PWM fuel pumps...Radium has some pretty trick stuff and they just dropped their brushless pump (requiring way less current) setup so it sounds promising, but expensive lol. Injector Dynamics is another conpany on the cutting edge of PWM fuel delivery systems but super pricey stuff too.
LOL...so you see this project can find itself spiraling into a deep rabbit hole that I haven't had time to really delve into at the moment...
Ryan Selcer
Colorado
Yes, with the XDI-35 and the DW300c, according to Matt at GH, it struggled to provide enough fuel when running full e85. It sounded like it worked, but it was right there on the edge. I've got the XDI-60, DW300c, and a set of XDI +50% injectors, so I know fuel supply will be an issue once I get this thing finished. One of the reasons I've been working on that surge tank project. Not much progress on that front yet as I've had a ton of things going on and it's not as easy as it sounds since our vehicles utilize PWM returnless fuel systems. I'd like to keep that functionality but I don't think the stock fuel pump control module can handle the current needed to run multiple pumps in a surge tank setup. Which means go to a bigger module, but the stock module receives event notifications from the PCM that I'm not sure how an aftermarket one will respond. So one answer is using Solid State Relays, but then you run into cost issues with higher resolution relays that are usually needed to control high output PWM fuel pumps...Radium has some pretty trick stuff and they just dropped their brushless pump setup so it sounds promising, but expensive lol. Injector Dynamics is another conpany on the cutting edge of PWM fuel delivery systems but super pricey stuff too.
Well if you need help with the electronics when that time comes let me know
See.....
Screenshot 20200630 211742 DuckDuckGo
Sideways
Screenshot 20200630 211806 DuckDuckGo
FiveLeeter918
Tulsa, OK
So all I really need to do is upgrade the two pumps and tune?
yes in our experience. We've only one 1 e85 10-12 SHO model and it did struggle a little with fuel pressure on full e85, but his DW300C was doing some weird stuff from the start so I haven't gone to much detail troubleshooting it. We've done several E85 2013+ cars with no issues though.
Can't speak for what Matt's doing, but it works great for us.
FiveLeeter918
Tulsa, OK
Sure, I can't seem to find them on my tablet or in our ticket system, which likely means the logs are on my work computer which is in our bedroom right now. I'll pull them in the morning and post some data.
Iqoniq
Atlanta, GA
720 CHP would equal about 500 bhp, right? I'm assuming 30% drivetrain loss.
bpd1151
Lurking Around
SHOcago 'Burbs
The drivetrain loss on this platform hovers between 23% and 24%.
bpd1151
Lurking Around
SHOcago 'Burbs
Doesn't matter what it seems. It is what it is.
Stated CHP (from FMC) has consistently remained the same throughout the GEN4 (2010-2012) & GEN5 (2013 and up) production runs.
That being 365.
Throughout the years, stock dyno pulls, (literally stock with no mods whatsoever) have consistently ranged from 277 to 285 on average.
Thus the previously stated 23% to 24% loss ratio.
