StealBlueSho
The stock cams are so small, im surprised it makes power past 4500 rpms at all... That's problem 1. As far as the pump lobe goes, our 4 lobe design actually has an rpm limitation compared to the truck 3 lobe design. Even if you could, you wouldn't want to go above the 4 lobe design. Just adding lift will satisfy your fuel goals.
Sssssooooooo where are the cams?????
