Catch can quick disconnect clips
Zpak
Es Aich Oh!
The region, Indiana
74C2792E AD26 4AB4 AB8B 539EC758074A
Anybody know where to find these clips? I searched the web, went to two auto part stores and even tried my luck at ford. (Stupid I know)
Called UPR and you can only buy the whole fitting not just the clip. I’d guess it’s 3/4”.
I knew it was only a matter of time before one of these broke. Today was that time.
SaveMelMac
Texas
I think Dorman makes some of those clips. Usually used for fuel line and tranny lines.
Zpak
Es Aich Oh!
The region, Indiana
I’ll keep looking. The dorman ones I found were all tiny. Red for fuel and then the even smaller white ones.
Jordan_R
Missouri
You can get them at Oreillys. I had to buy one when I snapped one swapping my LPFP out for the transfer pump line.
Zpak
Es Aich Oh!
The region, Indiana
Thanks, I didn’t check there.
I noticed the ones UPR sells now are like the factory fittings where the clip doesn’t come out. That would be much more convenient. I need to stop being cheep and buy the drain line kit.
FiveLeeter918
Ortiz Performance Sales
Tulsa, OK
The drain line would require you to mount the can in a different location. There just isn't enough room to get around the wheel well where it's located.
Zpak
Es Aich Oh!
The region, Indiana
ouch how'd you break it?
Just one too many in and outs. I always struggled for some reason to get those to pop out. There must be a trick that I’m unaware of.
Also, I was wondering about exactly that with the drain. I know the bottom of the can is pretty close to the fender well. Is that where the problem lies?
I always push the clip down, then push the actual connector towards the CC fitting. It comes off super easy for me.
