EPP intake installed.
CCXVI
Intake is on, definitely worth the $450. You get what you pay for and this is way better made than the rest of them. **** easy install too, nothing complicated or frustrating about it.
Power seems a bit better, but the butt dyno can't really be trusted. Sounds pretty much the same as stock, except there's a little extra noise at part throttle.
Md8HGWv
High on Ethanol
Just Ain't Care
USA
dinojc86
New York
Md8HGWv
I installed the ECOPOWER Noise maker delete on the other side. I see you just have the stock tube but blocked.
I powdercoated REd and I saw this cold air induction and it is the best design out there, just so expensive. Then to gett hem in Red is even more. Then I need the last two pipes and we are talking over $1k. I have been on the fence and your endorsement helps. Thanks
Md8HGWv
I just pulled the trigger, ordered the Cold Air Intake and the Hot Pipe Upgrade.
I already have the Noise Make Delete.
FiveLeeter918
Ortiz Performance Sales
Tulsa, OK
well worth it! Not only for the coolness factor, but also preventative maintenance against all the plastic and rubber potentially cracking under increased boost.
