4sfed
St. Louis, MO
jtreber
Indiana
Ok...I wasn't gonna say anything but.... What springs are you running. The space between the wheels and the wheel wells are one thing, but holy cow! Your wheels don't even touch the ground!
All stock suspension. I didn't use the double riser blocks for the pics so the lift wasn't at its maximum height.
Pull her out if the garage, loaded my new 100 octane AJPTURBO tune and went out and let her eat. Yeah buddy!
Jordan_R
Missouri
Good luck and let her eat!! I just mostly finalized my AJP HPFP tune and also my GH HPFP tune the previous day.
Csbbrah
Ky
Killed 2 o2 sensors on my failed downpipes install. The primary o2s on both pipes are in need of replacing now. Will have to cut the front and replace rear primary. Now i have a lovely CEL.
On the positive note I was able to drain and fill the ptu. I got a very scary amount of fluid out. Maybe 6 ounces. Used a suction pump and got all i could out. Flushed with fresh oil then refilled. The liquid that came out was barely liquid. Had a ton of oil paste that i sucked out. So where I failed I got some piece of mind on the ptu.
Some of the oil here. About a 1/3 of this is fresh oil from priming the pump. Scary stuff.
671cfe6ce6019c6ecd88ac97ab43806f
Sent from my LM-Q610(FGN) using Tapatalk
Geez the DP's being a pain, could have been a blessing in disguise.
Csbbrah
Ky
Funny thing is last month my vent tube popped off the ptu because I yanked on it too hard in an attempt to swap out the oil. Took it to ford to see if they could pop it back on and to check the fluid level because my ape hands wouldnt fit. They told me the fluid looked good. Rather irritating, but there wasnt any metal shavings in the oil I could see. Guess I'm lucky.
Raging Bull
Today my SHO cane out of hiding first time since Nov, 9 were gonna go on a easy ride here in a lil bit just to get the fluids flowing ran it for a while let any moisture out. When we get back she is gonna get cleaned up for the season.
Csbbrah
Ky
The downpipes are on. Just had to chisel a o2 sensor in half so I could get a socket on it. New o2 sensors in and catless pipes on.
A5ededbbc17aa6fb4283ccd0a66c55dc
markmoomnu
