LMS 3 bar V11 93 bounces off rev limiter
StealBlueSho
NA
Launch in awd, turn off the rears after launch. Im pretty sure hes on stock turbos. Id have to ask him if he ever got the billet upgrades for like 600$ he wanted. He may have had the upgrades and tells people their stock. Car is a total sleeper. Sho badges off and swaped to normal taurus vents on sides.
Sounds like the real deal!!! Of course... this video you speak of would help, should be that hard for you to post no? You watch it whenever people talk about the LMS EB SHO...
yaycandy
Aerospace Engineer
Hanover, PA
Im not posting a video, i got nothing to prove. Real simple. People know where i live, come over. Doors open to you people on here. I picked up a f150 ecoboost engine and tranny and i got another miata im swapping it into, i just gotta figure out the width issue because the motor longways are wider than i thought
StealBlueSho
NA
My vbox had a quicker 0-60mph in Fwd only mode with mickey thompsons up front. 3.6 second in sport mode, right after i got the tune from livernois. I never had the limiter issues when i got the tune. Must of been something i done. And yes it ran that quick with a low compression cylinder. But it never threw a code or even felt like a bad engine until 30k miles of hard driving later. Fwd pulls wayyy harder. And i hate fwd cars. I put wider tires on the front for that pull close to home. Ill let you know what rim width and size they are. Rubbed alittle.....more like alot but thats why i did it close to home. Babied it to my spot and let her rip after heating them up on the way there
I think it is a bit disingenuous of you to LIGHT UP Livernois about your blown engine when you KNEW it had a bad cylinder when you purchased it FROM AUCTION. Then you drop a tune on top of it KNOWING there is a pre-existing issue. Then admit to "30K miles of hard driving" with the above mentioned issues.
Then you talk about a video you have yet to post...
Then you talk about your three engineering degrees.. but somehow manage to screw up the fact that injectors are NOT measured in CFM..
I called the shop you spoke of, no one there has a clue about a 10 second EB SHO.. Gen1's and Gen2's sure.. for dirt track racing..
The list could go on but I think my point has been made...
I smell a troll...
yaycandy
Aerospace Engineer
Hanover, PA
Im not here to impress people. I seen a gtr do 8 seconds in person and the record at that time was supposibly 10 something. There are lots of people out there putting numbers down on the track and dont care for the publicity as some do. Ive seen 2 different sho’s beat the livernois record by at least a half second. I dont see them posting it all over the place. We are smarter than that. Mostly because we would lose our jobs. Yea higher up government jobs are cut throat with someone always behind looking at everything you post or do in life to take your job from you. And having fun is a no no
yaycandy
Aerospace Engineer
Hanover, PA
I smell a troll...
You must be a livernois fan boy also. I did not light up livernois. And i said i was upset with cody for posting that when the tuner even said that the pump is not needed. I dont care to impress people on here like some of the ego maniacs on here who are threatened by a car quicker than theirs. Yea its simple when you make 275k a year as an aerospace engineer. I could drop 40k in my sho right now and have it at 9 seconds with a rwd swap transaxel from my c6. But i honestly dont care to do so. I drive my cars for to have fun. Not to be a drag racer on the weekends and daily it on the weekdays
StealBlueSho
NA
No one in the government is gonna give two sh!ts about you racing legally on the track. Even if you work for them. And if you are racing on the street illegally then you lying about breaking the record as there is no way to properly time it.
StealBlueSho
NA
Oh now it just got fun... "ego maniacs" but then "I make $275k a year"... will one of the admins kick this joker out of here...
StealBlueSho
NA
Ha! Livernois fan boy huh? You clearly don't visit here much. I am about as impartial as it gets.. so much so that I probably have a reputation for jumping different tuners all the time..
Try again bucko.. go blow your Aerospace Engineer stuff somewhere else.
yaycandy
Aerospace Engineer
Hanover, PA
I smell a troll...
Cfm is flow rate. Lbs/hour is pressure. Not rocket science, which you know nothing of
bpd1151
Lurking Around
SHOcago 'Burbs
Don't you hold the title yourself at that track BAM_SHO???
yaycandy
Aerospace Engineer
Hanover, PA
I actually been online everyday for most of last year
yaycandy
Aerospace Engineer
Hanover, PA
Your just upset because my vbox recorded my sho quicker than yours with a worn cylinder and yes vbox is an NHRA approved device
bpd1151
Lurking Around
SHOcago 'Burbs
"Most of last year"????
You only signed up in July of 2018.
bpd1151
Lurking Around
SHOcago 'Burbs
Yes I am, 2016 True Street Champion.
Sweet! My memory hasn't failed me yet.
Nice job once again.
Maybe Curtis, and his mystery friend should line up with you, just like you've offered/challenged.
yaycandy
Aerospace Engineer
Hanover, PA
Im gunna upload my vbox result to their site for 015’ sho. Ill own the quickest sho until bpd just pulls his awd fuse and puts down 2second 0-60
shootinirons
