cali+Mocasho+
89 white 3.2 145k
Hi guys i did my front 60k and noticed my axles are toast. Always driped tranny fluid from the right axle seal btw. So i picked up some shosource axles and seals. Installed them using a bearing/seal press. Put anorbic (i know thats not spelled correctly)sealer on the outer sealto case, rubbed oil on the rubber portion to cvaxle. Pushed the cv axles in as gently as possible(Especially the half shaft on the passenger side since it was light) till i i felt a click and was unable to pull them out. The leak is only while driving. No leak at idle.
