Coilovers 101 - UPDATE- articulating mount issue solved!
shopartsnw
SHO Medic
Battle Ground, WA
Thanks. That looks really good, and I agree that looks like the best option and geometry. Thumbs up!
TimboSHO
Intermediate
Wyoming, MI
Ok, I finally got the car out and to the alignment shop (my work). The back didn't change a whole lot, I just had to adjust the height
a bit to get the rear ones even after driving it. The fronts stayed at the same height and no adjustments necessary. The front alignment was giving me issues until I realized that I should just take the upper factory plates off! That helped a ton, because I couldn't tell if the strut was moving or just the plate sometimes! The driver's side maxed out at -1.5deg camber (caster was about 5). Is anyone able to get more camber? I thought I should be able to get more with the adjustable mounts. I have them set at the middle dampening setting and they are very stiff, but still streetable. I think I will try the softest setting when I drive it to storage next week and see how that feels.
I had one question. The car has a little bit of hanging up in one or both of the mounts. When I steer I get some popping as it hangs up and releases. This also causes some memory steer issues (when I turn right it will pull right, when I turn left it will pull left). Is this just part of initial break in? I know it will make no difference on the track, but it a little annoying on the street.
So, I'm very happy with them, but only have about 6 miles on them too. The car will be going to sit for the next 6 months, so I will be very anxious to get it out in the spring and try them out!
IMG 20171026 183424171 HDR
shopartsnw
SHO Medic
Battle Ground, WA
For the camber, which direction is the yellow block bolted into the black plate? The yellow block is reversable, and it may have been bolted in the other way for shipping. One warning: on the last camber plate batch we expanded the slot distance to allow for extreme camber (customer request), but we did not expand the steel backing plate to match because we already had a lot made up. Most are fine with the range on the steel plate, but if you need more, you may have to lengthen the opening in the steel plate to match the aluminum plate. Does that make sense?
For the popping and binding, I always recommend dielectric grease between the cup and plastic ball and also between the plastic ball and the yellow block. It will help keep things from binding. If you keep having issues, please let me know.
Mike
TimboSHO
Intermediate
Wyoming, MI
Ok, I looked at it and the yellow block is to the outside, which makes sense why I couldn't get any more camber. In the spring I will flip those around and put some dielectric grease on. I thought I read somewhere not to put any **** on them as it just collects dirt.
I'm sad that I have to put it away for the winter, but hopefully I'll be able to give some more driving experiences on track in the spring!
Thanks for all of your help Mike!
yamahaSHO
E85 whore
Arkansas
I just received my beautiful new SHO source coilovers this week. I am an ASE certified auto mechanic, but I just have a few questions to get me started, and thought I would start a thread for all of the others that are waiting to put these things of beauty on their cars.
1. Should I tighten the top nut with an impact? I don't see another way, but with the nylon washer in the top nut, I'm worried about it spinning the shaft, and there is no way to hold the shaft with the adjustment on the top.
When there is nowhere to put a wrench or Allen wrench, I try to hold the shaft with my hand (phrasing) and a quick snug with an impact.
2. What spring preload should I use? It looks like for a sports car coilover, zero preload is mostly recommended unless you have problems after install. Anyone have any suggestions for the SHO?
Get the collar to touch the spring and tighten a touch more. DO NOT put any real preload on it.
3. Where do I even start with height adjustment? Just put them in as they are, get the car back on the ground and then figure out where I need to go from there?
Mostly a guess to start with. Install, lower car, measure fender to center hub, calculate what you desire for ride height and raise back up to adjust.
4. Sway bar preload. Not sure what the best adjustment is for the sway bars either. Do I try and keep the stock placement?
Lower car (4-post lift or lower on blocks), take out preload, and tighten down.
Irish Pride
Irish Inside
MusicCityUSA
What is the proper way to adjust ride height once they are installed?
TimboSHO
Intermediate
Wyoming, MI
Took them apart this weekend to flip the yellow block and greased them. Noticed some galling in the upper cups where they ride against the yellow blocks. After getting them back together I noticed that the sleeves that go over the strut shaft and in the inside of the articulating mounts are loose (should have a wider outer diameter?) and the mount moves back and forth on the strut shaft, which I believe is causing the binding (it was better after greasing, but not all the way).
Any ideas?
shopartsnw
SHO Medic
Battle Ground, WA
Any ideas?
I finished my research. Somewhere during the last batch of coilovers, our supplier for the yellow blocks changed the design to put a bulged area on the bottom where it meets the plastic of the spring mount. This could explain the galling of the plastic. You are the first one to notice the issue, so we do not know how many people could have the issue, but we think it was only a recent change in the camber/caster kits. I originally designed the bottom of the block to be smooth so it would easily slide against the plastic blocks.
To correct the issue, I machined off the bulge on a pair of the yellow blocks and can send them to you with a return label for your old blocks if you want.
If there are others with this issue, please email me at MIKE at SHOSOURCE dot COM and let me know if you want to make an exchange.
Mike
Irish Pride
Irish Inside
MusicCityUSA
I have yet to put mine together but I have been following Tim's install here and he's been keeping me updated on Facebook. I'll take a look at mine tonight when I get home and see if mine are flat or have the bulge. Thanks for being such an upstanding and outgoing seller Mike!
OG-SHOguy
Same as JBeck
Houston, TX
I just now caught wind of this potential issue, I have not installed mine yet either and i will check mine as well...Thanks for catching this.
Irish Pride
Irish Inside
MusicCityUSA
This is what i have? Correct ones or supplier changed ones?
41782510805 17750e0e5e o20180608_192656_30
42682241001 6cf406b3ef o20180608_192648_30
41782510895 61c32367c0 o20180608_192641_30
TimboSHO
Intermediate
Wyoming, MI
I will be pulling mine apart this weekend (hopefully) and I will take some more detailed pictures (I'm usually not much of a picture taker!).
Irish Pride
Irish Inside
MusicCityUSA
I was thinking of installing mine this weekend but now I going to wait and see.
shopartsnw
SHO Medic
Battle Ground, WA
Those are the design that could cause an issue. I know there are people using this design with no problems, but the original design was better. If you send me an email with your current address, we will send you a modified set with a return label to send these ones back.
- Mike
Irish Pride
Irish Inside
MusicCityUSA
- Mike
I sent you a couple of emails over the weekend. Did you get them?
shopartsnw
SHO Medic
Battle Ground, WA
Yes. Sorry I did not reply sooner. We were moving my daughter into a new house so I was away from my computer. We have your modified yellow blocks and an extra steel bushing packaged and it will ship tomorrow.
Mike
TimboSHO
Intermediate
Wyoming, MI
Finally had time to get them back out and apart. I have the raised part on the bottom of the yellow blocks, and that is what appears to be gouging into the top part of the articulating mount. Just need the new pieces and we'll try it again!
IMG 20180613 193409349
shopartsnw
SHO Medic
Battle Ground, WA
I am confident the modified blocks will solve the issue. I am surprised more people have not had the problem. It could be they run it looser, more ****, or something else, but we will fix it long term with the modification.
I recommend some **** between the modified block and plastic when you reassemble. Let us know how it works for you.
Mike
Irish Pride
Irish Inside
MusicCityUSA
What kind of **** do you recommend? Regular Lythium based grease? Do I need to put any on the articulating mounts. It says they are self lubricating.
