Coilovers 101 - UPDATE- articulating mount issue solved!
TimboSHO
Intermediate
Wyoming, MI
I just received my beautiful new SHO source coilovers this week. I am an ASE certified auto mechanic, but I just have a few questions to get me started, and thought I would start a thread for all of the others that are waiting to put these things of beauty on their cars.
1. Should I tighten the top nut with an impact? I don't see another way, but with the nylon washer in the top nut, I'm worried about it spinning the shaft, and there is no way to hold the shaft with the adjustment on the top.
2. What spring preload should I use? It looks like for a sports car coilover, zero preload is mostly recommended unless you have problems after install. Anyone have any suggestions for the SHO?
3. Where do I even start with height adjustment? Just put them in as they are, get the car back on the ground and then figure out where I need to go from there?
4. Sway bar preload. Not sure what the best adjustment is for the sway bars either. Do I try and keep the stock placement?
If anyone has more questions, feel free to ask in this thread as well. I'm just trying to get some information out there for everyone. Thanks!
One_Shot
Colorado
Great questions. I pretty much thought of all the same the same questions when I got mine. I did some research just on coilovers and it sounded like most coilovers are set up from the factory for the specific car they are designed for. So I was just going to install them and see what I need to adjust from there. However after installing the new mounts I got and the caster camber plates they don't really look like they will work at the factory settings.
I would like to add the questions that this may be the first time most of us in the group buy such as myself are going to have serious adjustment of our alignment settings. With the caster camber plates and I got adjustable control arms with my coilovers as well. What is everybody running for performance street settings? What is everybody running for race settings?
I was going to go off of this thread as a starting point.
https://shoforum.com/index.php?threads/alignment-for-95-sho.135444/#post-1473424
Also Sam says in this post for auto x that he was running 3.5 degrees camber in the front and 2.0 in the rear.
https://shoforum.com/index.php?threads/first-sho-ftd.127394/
I am very interested to see if anyone else replies though. Definitely will be watching this thread.
Irish Pride
Irish Inside
MusicCityUSA
I will be keeping an eye on this thread too. It will be a little while before mine are installed but I have been thinking of this stuff as well.
TimboSHO
Intermediate
Wyoming, MI
My car is a street/autocross car with occasional track use. My current setup is -1.5 camber in front (I think caster is around 4) and -1 in the rear. Toe in is zero on both ends. With the coilovers, I am going to bump it up to -2 camber on the front and maybe -1.25 camber in the rear as I see far to much outer tire wear when I autocross/track it, but I also still want it to be streetable as well.
shopartsnw
SHO Medic
Sponsoring Vendor
Battle Ground, WA
I will do my best to help. These answers are based on my experience running the original prototype SHO Source coilovers as a daily driver for approximately 40,000 miles and my experiences on our purpose built RX7 race car with coilovers.
1) I agree you should not let the shaft spin uncontrollably when tightening the nut. I personally use a rubber strap wrench wrapped around the chrome shaft (as high as possible). This usually lets me get acceptable torque on the nut. An impact with short blips will do it, but it is way to easy to overtorque the nut unless you have really good torque sticks, so I usually avoid an impact gun.
2) My best result for preload was one turn on the collar past zero preload. This has the advantage of giving you full spring travel, while holding the assembly together tight enough it won't jump out of the perch when you jack up the wheels or lift one in hard cornering.
3) For height, I tried to stay close to the height of a car on lowering springs. We had some customers that went as low as they could go, and it still worked for them, but I hated scraping the air dam on speed bumps. Unless you are corner weighting the car, make sure you measure to keep your left and right side on each end the same. Front to rear can vary to set stance, but left and right on each end should stay balanced. I you are corner weighting, or at least have a set of scales, all this goes out the window. Corner weighting is a science all its own and needs its own thread for sure. As an aside, I did run the suspension higher than stock during some winter snow driving. It looked ridiculous, but I was able to drive through deeper snow.
4) I have always been taught to keep the swaybay neutral at rest. Some people play with preload in corner weighting, but my best results were from adjusting ride height with the swaybars disconnected. Once my corner weighting and ride height is set, I will reconnect the swaybars with no preload. Since you get adjustability here over stock, you can finally adjust the swaybars to horizontal when the car is sitting at rest. Keeping the swaybars horizontal puts them in the middle of their range of motion and installing them neutral keeps you from having hidden preload.
5) Sway bars are another long discussion. Without coilovers, my personal preference on the Gen1 or Gen2 was 24/26 (or 22/26 with a Quaife). With coilovers (and the stiffer springs), I have seen people stick with 24/26, but I found that to be a little too stiff. I have also seen people delete the front bar and only go with a 19mm rear, but usually those cars had much stiffer springs on the coilovers. I hate to say it, but you may have to be prepared to experiment with swaybar sizes. Keep in mind, too much front swaybar will make the car understeer or push (you try to turn into a corner but the front wheels tend to slide). This is the safer condition for most street drivers. Too much rear sway bar, and the car tends to oversteer (the back end comes around and you spin). This is how race drivers like it, but it can be dangerous on the street. Be careful as you feel out the new suspension, and please let everyone know what swaybar combination works best for you (assuming you are on the standard coilover springs we ship).
6) Make sure you periodically check the tightness of your end link mounts and rear mount lock collars on the coil overs. They tend to want to rotate as you turn the car. I cut into the inside tire on the prototype car until I got it locked down. For extra safety, I cut off and ground part of the upper end link stud so it did not stick out as far to give me a little more safety (I was running wide tires).
Please let me know if there is anything else I can do to help answer questions.
Mike
SHO Source
shopartsnw
SHO Medic
Sponsoring Vendor
Battle Ground, WA
I forgot to add about camber and caster.
For a street car, I would run the stock settings for camber and caster.
If you are running a track car, you can adjust the camber from stock based on tire temps and wear. Caster usually stays the same (caster helps the steering return to straight and keep the car from darting)
If you are running autocross, you can get some pretty crazy camber, caster and swaybar settings to get good cornering. I do not have good autocross numebrs, but there are a lot of people on SHO Forum who do.
Keep in mind you can unbolt the gold pivot block and flip it around to get more travel in the opposite direction. We also expanded the length of the aluminum camber plat slot based on one customer's need, but I did not expand the steel backing plate. You may need to grind the inside of the steel backing plate if you need that extreme level of camber.
Welcome to the near infinite adjustability of coil overs.
Mike
SHO Source
TimboSHO
Intermediate
Wyoming, MI
Update:
Installed the mounts and found on the rears, you can use a 12mm open end wrench to hold the shaft from turning while using your 7/8" wrench to turn the nut. The curved wrench is helpful for this, but a straight one will work if you are careful. For the front ones, there aren't enough threads exposed for the 12mm wrench to fit on the top, so the strap wrench is helpful here. I think i might check the tightness once i have them installed with some weight on them.
I also set the preload. I just adjusted them until the bottom perch was against the spring, and then one full turn past that. Everything is nice and tight and everything is ready to go in. Now, if only I had the time to do that right now!
TimboSHO
Intermediate
Wyoming, MI
Got the fronts in.
IMG 20170923 095920219 IMG 20170923 144844688
I did switch this one to the other side, as I didn't like the end link mount bolts exposed.
The height was exactly where I wanted them when I let it down (26" on slicers with 215/60/16 tires). I started at about 27" with intrax springs.
Now for the rears....
IMG 20170923 190316076
TimboSHO
Intermediate
Wyoming, MI
I forgot to add, I also had to lengthen both tie rod ends quite a ways, as it was toed way out when I lowered it down. Obviously i will be adjusting the alignment, but at least eyeballing it will get it to the shop when I'm done without tearing the tires up. I put the camber adjustments right about in the middle, we'll see what kind of readings I get.
OG-SHOguy
Same as JBeck
Houston, TX
Came into my office this morning and had a surprise sitting on my desk! Got my first package of goodies from SHOsource... Mike over there is awesome! Love thise guys!
TimboSHO
Intermediate
Wyoming, MI
Another couple of questions:
1. with the adjustable front mounts, they came with 2 sets of nuts, one nylon locking but and one regular. Am I supposed to double nut? Do I put the strut towers brace between nuts?
2. I have russel's stainless brake hoses, how do you attach them? I modified the stock brackets in the rear, but the coilovers don't have a spot to attach them to. I used zip ties on the fronts before, so I will probably do this on all corners now, I just don't want them to come in contact with the tires!
I am so anxious to get this done, but it's been hard to find time lately!
shopartsnw
SHO Medic
Sponsoring Vendor
Battle Ground, WA
1) The normal grade 8 nuts were there just to fold everything together during shipping. The grade 8 nylocks were intended for final install. I have never had to double nut. I also installed my strut brace directly on the mount, but you could mount it between two nuts if you needed it mounted higher for some reason.
2) I also have Russel's lines and had no issue with rubbing, but you do need to watch the orientation during install. I was able to get a very slight twist to the line that caused it to tuck out of the way. You will want to turn your steering lock to lock to make sure it does not bind. If you still need more distance, I have used a light duty extension spring from a hardware store to pull the brake lines out of the way on super wide tires.
Let me know if you have any problems or you need more info on the springs.
Mike
TimboSHO
Intermediate
Wyoming, MI
Awesome Mike! Thanks for the reply! I didn't think I would have so many questions after being an ASE certified mechanic for 10+ years!
One more question: For the rear stabilizer links, do you put the eyelet towards the front of the car or rear? It looks like the bushings would sit more flush on the sway bar if I turned the mount towards the front.
Thanks again!
shopartsnw
SHO Medic
Sponsoring Vendor
Battle Ground, WA
Thanks again!
I mounted them in the factory position. You can raise or lower the mount height on the strut to keep the swaybar flat and the bushings happy. If you found a better way, I am definitely open to suggestions.
Mike
TimboSHO
Intermediate
Wyoming, MI
I installed the front strut tower brace and it hits the Camber adjustment bolts in the middle. How many people run a front brace on track? I never have, but I had one sitting around, so I decided now was a good time to throw it on. It looks like I would have to double nut it to get the right height...
shopartsnw
SHO Medic
Sponsoring Vendor
Battle Ground, WA
Everyone I know that used a strut tower brace with the camber plates opened up the center hole in the mounting plate to give access for adjustment. The more common method for doing this is to center punch four corners for the enlarged hole, drill the corner holes and play connect the dots with a cut off wheel or jigsaw. Double nutting is a good alternate solution as long as you have enough height under the hood, since this method will raise the strut brace.
Glad you are making it work. Keep us posted on how they perform for you.
Mike
