White line rear sway bar?
J persons
Natchitoches, LA
I have a '14 SHO with the PP options that include a factory rear sway bar. Is there any advantage, other than the adjustable end links, to replacing it with the White line sway bar?
SHO-moco
ct
I cannot answer this for you other then to note that on my 2010 I am installing the whiteline adjustable sway bar links in the rear with my factory sway bar.
Mahu24
Prince George, BC, Canada
The Whiteline is much thicker than factory and give two mounting options for your links. It made a noticable difference in stability around corners on my car
J persons
Natchitoches, LA
I've seen a post or two here that state I will need different swaybar end links to install the WL swaybar, and some don't make any mention of different end links. Do I need different end links or will the factory ones work?
SHO-moco
ct
Factory ride height? I do not have the WL swaybar, I got the adjustable links because my car is sitting on H&R springs which lower it. I wanted to take the preload out of the rear bar that lowering it created. I want to say a WL sway bar at factory ride height you can use the oem links but, and maybe even when lowered hence the 2 mounting holes for links? But I cannot answer that with certainty, someone with 1st hand knowledge will hopefully chime in.
12KSHO
