White line rear sway bar?
J persons
Natchitoches, LA
I have a '14 SHO with the PP options that include a factory rear sway bar. Is there any advantage, other than the adjustable end links, to replacing it with the White line sway bar?
SHO-moco
ct
I cannot answer this for you other then to note that on my 2010 I am installing the whiteline adjustable sway bar links in the rear with my factory sway bar.
Mahu24
Prince George, BC, Canada
The Whiteline is much thicker than factory and give two mounting options for your links. It made a noticable difference in stability around corners on my car
