Depends on what the dealer charges for the PTU. Off of eBay, you can buy from a dealer as low as $750-800 for the PTU. Add in the cost of new seals (not much), maybe some fluid to top off the trans (should not need but might) and 4.5 hours of labor. That is what your cost should be out the door. If you are paying out of pocket, you can ask to have the old unit back if you want, for dissection. Other than that it is just scrap metal ...
I gave the dealer a call back, told them their price is way to high. Service manager called me back about an hour later, said 1780$ out the door is the lowest they can do.can't have it towed to your independent shop from the dealer's?
hopefully you can trust this dealer to do the work right. be sure you are versed on the warranty etc. parts are 2 yrs/unlimited miles, not sure about the labor, maybe a year/12K?
Well, you're $520 cheaper than the initial quote.
So that's nothing to sneeze at.
Why drop $900 if you have a warranty? I would just have the PTU serviced and save the $.Dropping my car off Monday to have the tranny replaced under warranty and paying 900 out of pocket to have ptu replaced just for peace of mind. Hopefully everything works out.
Best of luck, you will want to change out fluid after a maximum of 5K miles, preferably 1K miles, assuming normal driving conditions. Cut in 1/2 for cityonly type conditions. This will remove all the breakin metals. No need to preset your PTU to xplod. Amsoil Severe Gear and Redline Lightweight Shockproof are very high quality fluids you should put on your short list.Picked up my car yesterday, new PTU, full synthetic oil change, tire rotation and 4 wheel alignment. Total out the door $1782.82
I don't know how they can put in a new PTU for 900$ as the list price for just the part is 915$ or so, plus labor. But if they will, I'd jump all over that!I have no clue what the ptu looks like. I would assume after 100k miles it's probably never been serviced. I doubt the warranty company would pay for the ptu and the trans. For me the 900 dollars is cheap peace of mind.
The transmission will already be out for replacement so they are only charging me for the ptu. No labor
