I'm not much into tech/electronics
gimpy
Pennsylvania
...but I've been curious if it might be possible to wire in a toggle switch that will activate the rear parking camera whenever desired?
Don't really know if there would be much use or reason for it, but it has made me ponder a few times.
SHOinVa
Tidewater Va
I am not a tech guy ether but I have also thought it would be nice to see behind you while going down the road. Problem is its an integrated system an there are a bunch of question that need to be asked before you can even figure it out how to get there. Is the camera always on but only accessed in reverse, does it it have a feed wire you can tap into, how do you view the feed, etc. My feed is into the entertainment system so for me the site listed could work or its possible for someone to just hack the system and come up with viewing page that way. Most anything can be done but I have no idea where this road even starts.
Charlie
Johnbigdog
michigain
The reverse camera (sent to it by the Body Contol Module) and APIM are looking for a reverse message over the controller area network (can) from the transmission range sensor sent by the P.C.M. for sure you would have to my to the system to tell the car it's in reverse when it's not.
This in not a simple put power here sinerio for the camera to work. This would have to be a lot as noted above. Not sure if that is compatible with both sync gen 2 and 3.
gimpy
Pennsylvania
Lol, and that is why not being too fluent with electronics doesn't bother me.
Thank you John
Johnbigdog
michigain
That's not a full explanation of the system but your welcome.
Modifying the electrical system and adding features in these newer cars are near impossible unless you now how to write software for the systems. And I don't know how
SHOinVa
Tidewater Va
LMAO I don't know who he is BUT That dude is smart
Johnbigdog
michigain
I do not consider myself smart. Everyone has something they are good at. I have experience. I read the books. Help out when I can the best I can.
By all means what I know just scratches the surface. There are much better techs out there. I do my part. I try to be a little better every day (some more than others) I learn and I help others learn.
