Sad news SHO is down
DerricksSHO
Michigan
My 2013 Taurus SHO blew up last night full exhaust E-blend tuned by BrewCityBost so now im in the processes of getting a used engine. Temps were cold but dont know if anyone else has had this luck and know where to find a good motor?
StealBlueSho
NA
Did you happen to be monitoring fuel pressure and knock? Meth?
Seems be a few engines that have crapped the bed in the past several months....
SHOinVa
Tidewater Va
I will open an appropriate beverage an toast the motor that gave its full measure in the pursuit of performance, keep us posted on its replacement. I cant find anyone I trust to install my down pipes much less a new motor, So Good Luck to you.
DerricksSHO
Michigan
No meth on the car I had my tablet that I use for gauges out of the car because I just got it back from the body shop and didnt remount it.
Was the engine warmed up before you got into the throttle. E blends and cold weather dont mix so well.
Former: 1995 ATX, 1992 MTX
StealBlueSho
NA
Yup... E mixes require more fuel, which if you are tuned, needs to be accounted for in the tune... if BCB did not know you were adding E to the mix then thats no good... Without proper tuning for E and mixed with colder temps you are asking for trouble... ask me how I know... lol
DerricksSHO
Michigan
Thanks.. BCB knew it was on a E-blend car was running good before last night. Seals on the turbo's been going so dont know if they finally just completely blew.. dont know. Got to get her back up in running!!
Jeff2017
These stories are what keep me stock.
limited02
Olathe, KS
Perhaps but the dealer can detect if the car has been tuned even when returned to stock. maybe when my warranty runs
out I will give a whirl.
I wouldn't concern myself about a dealer finding out. I have been tuned by LMS for the last 15k miles and I don't drive easy. I currently have 70k miles on mine with 30k left on the warranty and running the 93 race tune. I promise, if you wait until your warranty is over and then tune, you'll be kicking yourself for not tuning it sooner!
Jeff2017
Talk to me when you have 70k on the tune.:)
