KeithBRoberts
- Joined
- Jan 23, 2017
- Messages
- 30
- Reaction score
- 0
The fan and fuel pump does come on.
does it light up at all during startup i.e. is it possible it's burned out?It does nothing
All the other lights come on. I'll check the fuseCheck your fuses under the dash (above the brake pedal). I thought I had a similar issue recently where I had a difficult time pulling codes and my dash light was not lighting up. One of the small fuses (15A?, blue one) needed replacement
Do they make them just for this car? Where can I get one?if it won't light for any reason, its possible that the bulb is burned out or a previous owner could have pulled it out. it should have some ability to illuminate.
That being said, there are obdI code readers that are just a plug for the wiring harness with a red LED light that blinks just like the CEL on the dash. You would still have to count the flashes etc but it is a work around for a non functioning dash light
I replaced maf sensor. Nothing been done to either cam or crank sensorJust curious what sensor you are referring to, cam, crank and MAF sensors are mentioned at various points in this thread. Guessing cam . . .
