Miss hesitation
You could also have a vacuum leak at the intake to head mating surface or any of the intake runner couplers. Not likely but possible. Test wires:
that should trigger a code of some kind. backfire up there could be vacuum leak, problem with fuel delivery, or timing is off. Since you have had the intake off several times I would check into vacuum leak and take the intake off, take your time and loosen the snakes so they are flexy until you get a good seal at the head and tighten everything up. I think I would have to confirm timing is correct at this point and then go after fuel and spark. These cars have been known to jump a tooth or two at the timing belt and is worth looking into
I think it will be a vacuum leak, since I've seen these cars with the cams off a couple teeth and they did not backfire (although that is a possibility). The intake hoses are old and hard, and you almost always need to loosen them to get a good seal when you reinstall the intake.
ozzy smith
Ima try that this weekend I would just slap the intake with out loosing anything but makes sense worth a shot thanks guys . I'll let you guys know what happens
I made that mistake in the beginning too and why I mentioned loosening up the couplers. Helps it seat flat correctly and seals at the runners when they are loose first
ozzy smith
It makes sense and it's hard cus I work 7-5 and sun is going down by 530
ozzy smith
So I did it . Still has a miss but not that much more power . But not like the day I got her . Also I forgot to mention sometimes when I get on it brake light turns on .
zoomlater
Seattle, WA
If it turns on for a second, then goes off, you probably need more fluid in your brake fluid reservoir
Clover8686
Try cleaning the plugs and make sure the boots are snug, on the 1st bank they can be tough especially on the 3rd cylinder
92 3.0 sho mtx
I had no codes on my previous 95 MTX and the fuel pressure regulator failed. It was up at 80psi and I had no codes, but a constant stumble around 2000 to 2500 RPM. Putting in a new regulator helped some, but it also needed plug wires to get it running better. Check the pressure at the Schrader valve
92 3.0 sho mtx
Ok so if had this 92 for about 3 years now been trying to fine out what was going on with it has the same problems as far as the 2000 to 2500 rpms what should the fuel be and when I go easy it's fine just when I go from 800 rpm to wot it dose it but only at them same spots so and was it and mine hard to start and for get it after it's wormed up any one got any thoughta
