Seats, engines, transmissions, and other parts.
Status
Not open for further replies.
1MADSHO91
Drive One
Monroe, Ohio
I noticed that you are near Grand Rapids Michigan. It might be cheaper for you to come and pick it up from me. I am located about 30 to 45 minutes south of Dayton Ohio.
nathan_G
@madsho, I am familiar with Monroe, I lived in Sharonville and Centerville for a little while. I can definitely plan a trip for the right price. o_O What is your price at these days.
@Dingle, you are funny. ...putting an engine in a $5 flat rate. Ha!
Thanks! -NG
95ss
Montana
Just posted in the wtb section.........I am looking for the drive belt tension assy, to be clear....it is the spring loaded tension device with the idler pulley on it that maintains tension on the belt that drives the water pump, alternator, powersteering pump, etc....Thanks
1MADSHO91
Drive One
Monroe, Ohio
Which one do you need?
95ss
Montana
Hi, Those do not look like mine
I am looking for the serpentine tensioner assembly on a 94 3.2 atx , to be clear .....I am talking about the spring loaded assembly that has the idler pulley that keeps tension on the main belts that are driven by the harmonic balancer and run the ps pump, alternator, water pump and air conditioning compressor.
Thanks
bkarr443
Looking for 3.2 turbo motor with turbo still on and 5speed trans with no major damage. I can rebuild if needed just want to put it in my 99 cougar
1MADSHO91
Drive One
Monroe, Ohio
I have a 3.2 short block with 5k on the rebuilt and heads to put on the block. I don't have any turbos or 5 speed transmissions.
Sent from my SCH-I545 using Tapatalk
Status
313tiger
