Strange AC and Electrical problems
DJSHO91
Durham, NC
Driving my 91' yesterday, when suddenly the AC compressor cut out. Fan is still blowing, but everything is warm air. I went to lower the dr frt window and NOTHING. Tried the other window switches and the same thing-Nothing. And YES, I checked the window lock-out button. Then noticed my radio has cut out! The pwr dr lock, dash lights, IP, lighter and cruise control still work. I've checked the fuse panel, but nothing is out. Any ideas? Any help greatly appreciated! :salute:
mrecoolgar
SHO NUP
Hershey-PA
Check the battery connections.
Remove them, clean them, grease them.
Reinstall and make tight.
Check for loose grounds.
the ccrm has nothing to do with door switches or radio not working.
DJSHO91
Durham, NC
Checked all the fuses and nothing blown. Disconnected the battery and removed all the fuses. Took some sand paper to the battery terminals, and some emory boards to the fuse receptors. Got everything reconnected. She fired right up and everything is working fine. Don't know if I fixed anything, but I drove around for about 40 mins with no issues! :salute:
I have seen fuse connections get cruddy enough to cause problems, so possibly the r/r of fuses cleaned that up enough to make it work.
