Connector needs a home. Not sure where it goes
eacyde
Pinkley Taurus
Calgary, Alberta, Canada
Can anybody tell me what / where these 2 plugs go?
Hopefully somebody can pop their hood and trace where it goes. One of them looks like it was never plugged in, the other used to have a partner.
Plug in the middle by the heater hose
This one comes from the harness by the firewall. See next pic
shocar
shocrazy
Bend
There is a sensor behind to the right of the ford logo on the intake ( next to the black barrel shaped vacuum object.. If you look back there and the plug in port is empty, then you have it. Otherwise it might be just a left over plug from the harness that is not used in your SHO. There are several on the harness that aren't used but they normally have a plug . On the top there is also sensor... I can't tell if it is hooked up as your index finger is blocking the view
93markVIII
MO
for the 2nd one, that is the general location of the IAC valve. is it hooked up?
BlooDSMeaR
comufornia
Down on the back sise of the motor is a plug that looks like that it goes to some sort of water temp sensor. make sue thats plugged in. should be the longer lead that was in the 2nd pic
the first one goes nowhere - there is a connector back there with nothing to plug into that apparently was just there to confuse us when we work on the car...
eacyde
Pinkley Taurus
All the above mentioned items are plugged in. I need to check more on the temp sensor.
Can one of you pop your good and trace the wire?
AREA 91
Area 91
As stated, the first one does nothing.
What are the colors of the wires in the second plug?
If they are red and green, they go to the secondary butterflys (IMRC).
DO NOT mix up the IMRC and EATC plugs! It will blow the IMRC circuit inside the computer!
eacyde
Pinkley Taurus
The wires are yellow and black. I snapped a few more pics. the wire seems to naturally want to go by the brake fluid reservoir.
93markVIII
MO
hey i found it. putting up some pictures.
its that sensor on some pipe way down.
hawkeye18
Sorta cares
Norfolk, VA
The first one does not do nothing.
It is the test port for VAPS. If you look in the manual it will show you how to ground one of the wires to have it do a self-test routine.
gmail
Well-Known Member
sunbury pa
Area91 taught me sonething a few years back... do not mix the vaps with the butterflies.. they can reach and will blow out the secondaries circuit. . Red green think Christmas and secondaries is fun like Christmas is how he taught me... never forgot that one... thanks area 91 lol
