No Fuel
jon93
Philadelphia Region
What are possible reasons all 6 injectors don't fire when I have timing, spark, and pressure at the rails in my 91?
and it could also be bad wiring / bad ground anywhere in that circuit.
jon93
Philadelphia Region
All six fuel injectors were bad. Replaced them all and she fired right up.
jon93
Philadelphia Region
This motor sat for three years under my ownership and who knows how long before I owned it.
that would have been helpful information to know in your first post, as we would have immediately told you to check if the injectors were gummed up...
Glad you got 'er up and running! Fuel injectors are an oft neglected part on this car. Probably best to get them professionally cleaned & flowrated if you intend to keep 'em.
jon93
Philadelphia Region
hindsight is 20/20
I assembled this engine from a bare short block. It could have been anything.
gmail
Well-Known Member
sunbury pa
Id be inclined to think its something else.. check that ground wire thay sits in the injector valley
gmail
Well-Known Member
sunbury pa
Yeah I did but 6 injectors went bad at the same time seems far fetched.. I had a jeep that sat for 2 years and 2 injectors were bad not 6..
Also replacing the injectors might have wiggled the wiring or the ground which made contact again
jon93
Philadelphia Region
You're logic makes sense. I didn't want to believe it at first either. I tested all six injectors. All six injectors are stuck. You may test them yourself if you wish but you would be wasting your time. :)
