LJRuddy
Pop lock n drop
Picked up a 96 SHO with 236k. Car sat for over a year due to a coolant leak. Got that fixed and the car is now driveable.
My issue now is the heater. The engine warms up normally, cooling fan kicks on when the upper hose reads ~185 on my temp gun. However, I cannot get any heat from the heater. The engine has gone through 4 heat cycles since I replaced the coolant and the fluid level has not changed at all. Do I have a plugged system somewhere (heater core) or could the EATC not be switching to hot when I adjust the heat? Is there a test I can run on the gen 3 EATC like you can on the gen 2? I'm fairly confident that there is no air in the cooling system as the engine temps are all normal according to my temp gun.
If I do have a plugged core, what product would you recommend to flush the coolant system out? I usually just flush with water but I feel like the possible plug is a bit more severe since I've heated the car up several times and nothing has broken free.
EDIT: Found the self test on v8sho.com. EATC displayed 024 and 022 fault codes. Is my BDA bad?
