I looked in my Chilton on MAF testing nothing. I did find this on line. Maybe some helps. Maurice
http://easyautodiagnostics.com/ford_maf/maf_sensor_ford_1.php
Refer to your wiring diagram to make sure. Off road SHO good idea. I would check them all the way back to computer connection in case of wiring goof. Use care if using test probe in computer side of 60pin connector. You can actually spead the connection and wide up with a loose connection. I would unplug computer [prevent reading thru computer] and use the wiring side of connector. Maurice
