Water Pump
Snaaky
Ontario
Today driving to work the water pump went on me. It's a 93 3.2L I'm going to attempt to replace it myself. What does it involve to do this job and is there anything else I should replace while I'm doing this? Are there any guides available for this?
Thanks in advance!
sperold
Last to Know
Make sure it is the pump.
They usually give you lots of warning by leaking out the weep hole with enough volume to shut down your crank position sensor (CPS). Get a dentist's mirror to confirm the weep hole leak. I have never witnessed an impeller seperating from the shaft, which is quoted a lot at service centers.
Snaaky
Ontario
Oh, it's leaking! think big clouds of white smoke and enough coolant on the belt to make the power steering pump slip. My mechanic put pressurizer on rad and coolant sprayed out of the pump. you can also feel a distinct wiggle in the bearing. Thanks for the suggestions! :thankyou:
Snaaky
Ontario
Help!
So, I got a water pump. (it's in a CARDONE box 57-1458) It looks like it will fit but it's missing the threaded hole where the belt tentioner mounts to. Is this normal? Wrong pump? Is it ok to put the tentioner back on with only 2 out of 3 bolts?
Second Question: The lower timing belt cover on my car is missing. I'll likely be driving it this winter. (Southwestern Ontario) Should I be trying to find one of these? What are the risks of the timing belt skipping? Or is it going to **** the CPS sensor? at least it would be easy to change!
Thanks again for any help you can provide!
K-Dawg
Treasure Coast, FL
I don't remember for sure on an ATX, but I think that belt tensioner bolt goes through the hole in the water pump and threads into something behind it (rear water pump housing?). In other words, it's not supposed to thread into the actual water pump housing.
I recommend installing the lower timing cover.
Snaaky
Ontario
Well, after looking around on the intertubes, It appears that my 3.2 engine has a 3.0 water pump and tentioner on it? This car has been changed to MTX. Would that have anything to do with it?
I'm confused :S
AREA 91
Area 91
If you are running the MTX 2 belt setup, you need a 3.0 pump.
K-Dawg
Treasure Coast, FL
Do you have one accessory belt or two? ATX = 1 belt, MTX = 2 belts
The 3.0 and 3.2 water pumps are in fact different. If you look on RockAuto or Advance Auto Parts, etc. you can see the difference.
Snaaky
Ontario
What is the worst that could happen if I don't? The former owner does not have it.
Snaaky
Ontario
There is 2 belts. talked with the former owner. It is a 3.2 engine but all the belts and pulleys are from 3.0. I need to get a 3.0 pump. thanks for your help K-Dawg, Area 91!
K-Dawg
Treasure Coast, FL
You could get crap in the timing belt, the timing belt may degrade faster, CPS may fail sooner. Some people don't use them, but I feel like they're there for a reason.
Snaaky
Ontario
I'm going to order another water pump. Any suggestions on which one to get from rockauto? PRONTO is cheap.... Anybody try one of those?
AREA 91
Area 91
I really recomend having the timing covers in place.
Post in the wanted to buy section here on the forum.
Some of us have LOTS of sho parts (like me)!
leek157
illinois
i am currently replacing my water pump on my 95 mtx, does anyone know if there is suppose to be some sort of gasket between the rear part of the pump and the engine block?
Snaaky
Ontario
Assuming it's the same as my 93, There should be an o-ring. It will fit into a groove on water pump. You should replace the one that is on the pipe as well. Any hydraulics shop should be able to find o-rings to fit.
K-Dawg
Treasure Coast, FL
Like the above post states, there is an o-ring. It's included in Fel-Pro ES70425. The water pump o-ring is the thin one. The larger ones are for the crossover tube.
I once tried to find one of these o-rings at the local parts stores and couldn't find an exact match. Didn't try a hydraulic shop.
