Taillights, sunroof, interior bits, and more!
Gez89SHO
LEGO SHO
NE Philadelphia, PA
I recently sold my '89 and no longer need the spare parts. All will fit a Gen 1, Some will fit Gen2 as well.
I prefer not to ship these- local pickup only, cash in hand. Zip code 19053.
If you need delivery I can do that, however you need to pay through MO.
Underhood:
MTX, Condition: Removed from a donor car and kept as spare, never used. $200. SOLD
Complete cable shifter and cable assembly, with brackets and interior bezel. Plus screws/hardware. $10. SOLD
SHONUT Shim kit: SOLD
I have one New, never used "M" IRCM, $75 for it: SOLD
3.0 idler pullies, used, take $10 for them: SOLD
Secondary intake valves, I have one of them, $ 10 : SOLD
Radiator overflow tank with sensor, free: GONE
Lower coolant hose, good condition but used, free: GONE
Interior:
Original Amp from the car, nothing wrong with it, took it out to add a aftermarket radio, free:
Turn signal flasher module, I have too many,free, come take them away: GONE
Interior Clock, free: GONE
Body:
Gen 1 Taillights with Yellow turn Signal. Good condition. $30
Sunroof glass (with seal) from a 89, will fit any Taurii from Gen1-2. $20
Various:
Grab box of stuff- Various clips, bulbs, switches, and engine parts. Don't want to go thru all of it, but these are spares I kept around "just in case". $80 for the whole thing.
Relays, fuses etc. Edit: Autolamp dimmer is sold now.
Valve cover bolts: SOLD
Starter relays:
Interior switches, throttle cable:
Note the 89 foglight switches, rare 1-year only item:
MAF, Oil cooler hoses, Coil, Wiper motor, old foglights. Edit: Foglights are sold now.
More to come...
Gez89SHO
LEGO SHO
NE Philadelphia, PA
More Stuff:
Interior:
Turn signal/Wiper/Flash to pass combo switch, $15: SOLD
Underhood:
Crankshaft Position Sensor, new in box, $20: SOLD
Strut mount rubber insulator, new in box, $5: SOLD
Strut Mount, new in box, $10: SOLD
Front main oil seal (belt side), new in box, $5: SOLD
MTX axle seal, new, $5: SOLD
gmail
Well-Known Member
sunbury pa
wow OEM plate on the trans where the lines and stuff run... dont see that often
pitaSHO
Why do I do this to myself?
Lewisville, TX
Is that a two-plug wiper motor? I'm assuming it works. Price and shipping for that and the clock to 98682.
bradman
Everett, WA
PM sent on:
Crank Sensor, Fogs, Seals, Pulleys, and Shim Kit (if still available).
Thanks,
brad
Gez89SHO
LEGO SHO
NE Philadelphia, PA
the wiper motor is a one-plug. pulled out of a jy car, worked when removed.
the clock is a free item, but shipping is going to add $ 10 to the cost. payment through MO.
dan.delargy
