Suggestions for Gauges.
vortex2450
Buying Parts...
North Carolina
Hey folks,
I was thinking about it and figured I'd come to SHoforum first; I was curious as to what gauges would be deemed most useful to run in a supercharged SHO.
I am thinking I want to mount 4 on my STB and slot out a hole in the cowl of my cowl hood so I can see them plus another 3 on the pillar.
So 7 options total.
I'm thinking...
-A/F wideband
-Boost/Vac
-Oil Pressure
-Voltage
-Engine Coolant Temp
-Exhaust Gas Temp
-Fuel Pressure
No ridicule please, this is why I ask here :)
-Josh
jayro
Auburn, In
a/f, oil pressure, oil temp. coolant temp and boost. You could add fuel pressure too.
vortex2450
Buying Parts...
North Carolina
Oil temp is a good one. I guess between voltage and exhaust temp I would choose exhaust temp, unless I could squeeze 5 gauges together under the hood.
-Josh
somedude_001
Western NY
I would drop coolant temp, you already have that on your dash + if your coolant temp gets too high you will see that in your oil temp so in my opinion save your money on coolant temp gauge.
rather than a boost/vac gauge you might consider just a boost gauge. Your engine vac is not really something you need to see. unless you just want it. I would not get a volt gauge, but again only to save money. you have a light on your dash to tell you when you are screwed. EGT is a neat gauge to watch but from a tuning standpoint I hear it is not that critical. My last boosted SHO didn't have EGT, but on the other hand my SHO powered camaro has EGT for left and right bank. Not because I need it but just because I want it.
My gauges on my last turbo SHO were AFR, boost/vac, oil temp, transmission temp (I had a auto). If you are budget minded I would replace the trans temp with oil pressure and call it good. If you want more gauges just for the sake of keeping a eye on your toy go for it.
for a fuel pressure gauge most aftermarket FPR's have a port that you can screw a gauge directly into. I would install one into that port so you can take a glance at it when you are under the hood if you are having issues.
edit:
I don't mean to come across with such a strong opinion but I have been pricing out good quality gauges over the last 2 weeks and they are EXPENSIVE. So just know that my input has your wallet in mind
vortex2450
Buying Parts...
North Carolina
It's a consideration but I think I would like a numbered readout versus "it's on "O".
If I just went with a boost gauge I'd imagine it wouldn't move much unless I was getting on the throttle, correct? I to have the vac as well, my line of thought is I would rather have and not need it than need it and not have it.
I think voltage is important, that voltage indicator desn't come on until about 10.5 volts and when I'm running a boosted car I am going to want to know my voltage so that I am confident my electrical system is functioning smoothly and has plenty of power.
You raise a good point with EGT, I probably will have my y-pipe modified into my borla catback (has dual pipes after the resonator) to create a true- dual exhaust set up so I will probably need two EGT gauges if I got that route..
I think your last sentence just about sums how where I am coming from. :sun:
That is not a bad idea, it could save me a spot for the the other EGT..
edit:
I appreciate your input, honestly I've put cost aside at this point. I am going to use Autometer Phantom Gauges w/ electrical senders, the cost is going to be somewhere near $850 shipped. The main reason being that I don't want hard-lines running to the gauges on my STB because I will have to remove that anytime I work on the car.
My biggest aspiration is to do things right (the first time) and that is what I plan to do.
-Josh
somedude_001
Western NY
I try to stay budget minded when I suggest things because many people on here work hard to keep the cost down (nothing wrong with that)
I was strongly considering using the autometer elite serise for my SHO powered camaro. I have not used them in person but they look really bad ass on youtube. They carry a high price point though.
For EGT if you are going to monitor dual EGT outputs I might recommend 2 PLX EGT modules and 1 PLX multi gauge. It will let you look at both left and right banks on one gauge and can be set up for warning monitors. This option is probably one of the better ones I found on the market. I just picked up their wideband kit and 2 EGT kits + 1 additional gauge. This will let me use one gauge for wideband and one to look at both banks for EGT on the other gauge.
wideband kit (including sensor and gauge) 199
2 EGT kits (includes sensor and modules) 198
1 multi gauge 99
package discount -32
$464
also allows for dataloging
Phoenix
SHOHOLIC
QC , Canada
Before you buy anything check with speedhut.com
Bought 2 kits from them (can also buy separate)
Ishodu
I have a dual gauge for sale, pressure and temp see classified. Also SHONUT sells PLX gauges you can put 4 in 1 or even more depending on what style of gauge you want. Here is the PLX I installed.
IMAG0163
I have it set for oil pressure fuel pressure oil temp and trans temp.
yamahaSHO
E85 whore
Arkansas
That's what I was going to recommend. I've got one on in my STi as I hate that I hav 5 gauges in my SHO. I will likely do the same for the SHO this year to cut down on gauges.
jon93
Philadelphia Region
IMAG0163
Nice gauge!
A couple questions.. Is this the DM-100? Can you program the color of the reading to change (to lets say red) when it reaches a danger zone? When you reach the danger zone, can you program it to blink or get your attention somehow?
[YOUTUBE]V8rZWw9HE7o[/YOUTUBE]
Necessary.
Ishodu
You can get it to flash when it goes to a certain range yes not sure if you can change the color at that time or not. But you can change the colors of the display to what ever you want. I believe it is the 100
