Identifying stage 1 cams
SV&HOdan
Pittsburgh PA USA
Anybody know how Sho Shop stage one cams can be identified assuming
they're already installed? Any unique markings? I bought a set of heads and
the fellow claimed they were sho shop stage 1's...I'd like to confirm before I
intall or try to sell. Thanks in advance!!
dan
LOUDSHO92
Rancho Cucamonga, CA
I would have to pull out my cams but I can tell you the cam will be shorter then the stock cam. It also will not have the relief around the journals like the stage 2's.
Johnlemon
Glendale, Arizona
mic the lift and compare with stock cam values
MTX Intake .348" Lift
MTX Exhaust .328" Lift
ATX Intake .328" Lift
ATX Exhaust .328" Lift
SinisterSHO
Rust free
630, IL
I doubt that any SHO Shop cams actually measured what they were advertised. But, you could measure and see if its the same as stock. The stage 1 cams I had in my 93 sounded like a sewing machine because the re-grinds weren't as smooth.
jedhead
westminster,ca
If you have reground cams, either you will have lash caps on the valve stems or very thick shims. Remove the shim and check.
Bob
