New EcoBoost Development....
EcoBrick Bob
Clear Lake, IA Naples, Fl
Pretty sure Ford tried a "stroker" kit. They tried to make it a 3.7 L as far as I know..but kept breaking it.
Definitely happened... G8 friend was a contract Metallurgical engineer on the EB project. They had issues after a few hundred miles with the 3.7 L variant.
You should read the lengthy thread on Flex Net forum regarding Ford and their possible denial of warranty issues.... Getting a bit heated at times... But at the end of the day... It is what it is.:munch::munch:
thePUNISHER
ford tranny man
CT
Hmmm. I wonder what was breaking.....And why it is holding together in the 3.5.
Crash712us
Chasing my tail
MI
Hmmm I wonder what the stroke/bore ratio is, it couldn't be that much different. When picking up only 200cc more displacement.
onebadf150
New Orleans
thanks guy for the info!
I think with the right turbos and fueling the 3.5L will produce enough power to make us all grin:sun:
LMSRick
Livernois
Westland, MI
The flow gains are almost unbelievable, but as most people know, numbers aren't everything. We need to get the port finished, then digitize and CNC it and try it on a car to make sure drivability doesn't suffer.
From SVTPerformance.com
PRI 2011 Day 1 S 07
PRI 2011 Day 1 T 06
PRI 2011 Day 1 T 05
PRI 2011 Day 1 T 04
PRI 2011 Day 1 T 03
PRI 2011 Day 1 T 02
PRI 2011 Day 1 T 01
-Rick
EcoBrick Bob
From your previous post, the Intake Flow increased 110 CFM That's a 60% increase.
The Exhaust flow increased 37 CFM or around 25%.
I'm impressed!!!!
Get those puppies on a car!
Paulford8
Central IL
I'm impressed!!!!
That is incredible. Cant wait to see what this does on the car!
LMSRick
Livernois
Westland, MI
I'm impressed!!!!
Yeah, that's why I said the gains seemed unbelievable....
Now to get them on a car.... :woo-hoo:
-Rick
thePUNISHER
ford tranny man
CT
How hard is it to tear down the EB engine to install? What is involved with fuel system, cams etc, compared to a OHV GM engine? Looks to me like a lot more work.
not something done in your driveway thats for sure! the engine/transmission/subframe are dropped out the bottom of the car using a powertrain lift....then the heads can be removed....... cam timing isnt really any different than any of the other ford v6 ohc engines.....
ive already had the heads off a 3.5 fusion. i dropped the powertrain out the bottom....
my curiousity is how much boost the head bolts can take before the heads lift off the block......doesnt seem to be an issue yet.....if one were to go and do a head swap though i would think you would upgrade to arp fasteners if they are even available....
boost levels will drop like a brick with increased flow #s like that. i would say installing those heads would mandate a turbo upgrade......
EcoBrick Bob
I was amazed at how much better they flow. On my G8, the stock heads flow great, so when I had them ported, I gained around 10% or less. Likely wasn't worth it, but it gives me bragging rights!!!!!
I figured it had to come out the bottom. Would very hard to take off rear headers, maybe impossible from the top.
So... if the head gasket blows due to boost.:dribble:.. it means on needs to get the heads CNC'd at the same time!:angelnot::angelnot:
Johnny Langton
Texas
Interesting flow gains. Now we need to see some stockish profile cams with .500" lift to take advantage of all of that newfound airflow.
JL
somedude_001
Western NY
You may be right but there is still something to be said about making more power on less boost. At least until there is a big turbo available for the 3.5 EB
bmytych
