Art5
HI all.
Got abs pump and computer out of the car, since it never work , because someone cut one sensor from the harness, then I damaged few more sensors while changing struts, and finally few lines rotted out.
So, I T-ed each output on Master cylinder and bypassed the whole ABS stuff directly to wheels.
Not working right!!!
First brake-front left wheel locks up. Second brake-left rear locks up first, then front left. Sometimes both rears first then left front.
I have GTP control arms on the car and , I think, bias plugs. Car is "95 with gen3 front brakes and stock rears.
I was thinking if I HAVE to swap out master cylinder, if I do, do I have to get a different booster too, or what can you guys suggest?
Thank you again.
Thank you again.
