The SHOforum 12 second Challenge.
darreli
Run'n from BPD
Michigan
I'm guessing that map is counting atmospheric as 1 bar and he shooting for 28 PSI? SHOboom!
Or I'm reading MAP incorrectly as a sensor.
2 bar is 14.7 psi....looking more for 18 or 19psi. Not sure what the stock turbos are good to. I know one guy is running 19psi and hasn't had a problem....yet
yamahaSHO
E85 whore
Arkansas
Possibly on another planet or at ridiculously high altitude, but here on Earth (pressure at sea level), 1 bar = 14.5037738 pounds per square inch.
2 bar can be related to to 14.x PSI if you are referring to your starting atmospheric pressure as the first bar. Just about every gauge you see will reference atmospheric pressure as "0" (bar or PSI).
darreli
Run'n from BPD
Michigan
Do you ever have anything positive to say?? Just curious.
"i'm" not referring to anything. There is a 2 bar MAP on the car and it good to 14.x psi
yamahaSHO
E85 whore
Arkansas
Two things:
1. Reference post #170, it was directed towards you.
2. Explain how what I said was negative.
It is referencing atmospheric at 14.x PSI or 1 bar. Discussion is so negative these days. :rolleyes:
Toolman
Boost it!
Grand Lake, Oklahoma, USA
MAP is not a gauge jason, it is a sensor, an absolute pressure sensor, and as such, the pressure in the manifold is at 1 bar when the engine is off.
EDIT: NM, posted this while you were posting above.
Toolman
Boost it!
Not sure what level of misunderstanding is occurring here. A 3 bar sensor is needed anytime you will be seeing over 14.7psi of boost pressure. It does not mean you will have to use the entire capacity of the sensor (29+psi).
darreli
Run'n from BPD
Michigan
Two things:
Sorry dude....sounded like you were trying to bash me. That's the problem with reading stuff in text I guess.
To expand a little on Toolman...yes I was talking about the MAP (manifold absolute pressure) sensor on the car. I'm limited to 14.x psi without changing the sensor to a 3 bar
yamahaSHO
E85 whore
Arkansas
I mentioned it being a sensor already.
I wasn't sure if he meant M.A.P. or map (tune). Either way, there wasn't any harm and I'm sorry if someone is way too easily offended by discussion, since I didn't name call, point fingers, curse, etc...
Toolman
Boost it!
I don't see him being offended at all, just calling it like it looks, he would not be the first. He is new, and unlike the rest of us, is not used to your complete lack of diplomacy! :)
I see, map versus MAP, makes a little bit of sense I guess.
yamahaSHO
E85 whore
Arkansas
No worries. It makes sense now.
typhoon5000
Ferd Enganear
Shelby, MI
I think if I can get up into the 3 bar boost range, it could run 11's
I understand what you meant now, but in your post you said 3 bar of boost, not 3 bar MAP, which equates to about 43.5psi of boost over atmosphere, which is why I was all :oogle:.
Sho Amo
SmkTyresntDrugs
Olney, Md
lol @ 101mph trap speed. I ran 12.8@ 113
Jeez I need awd.
Edit: forgot to add, good job! I love that your pushing the envelope. I was actually thinking people werent going to run these EB shos as hard due to their price.
yamahaSHO
E85 whore
Arkansas
Jeez I need awd.
If you're talking about darreli, he got a 110mph trap.
Sho Amo
SmkTyresntDrugs
Olney, Md
Hey your right I was looking at the 1000ft. I still trapped higher :)
1.8 60' will do it lol.
darreli
Run'n from BPD
Michigan
Thanks man! Yeah, I'll push it as far as I can. You did definately trap higher and I honestly thought my MPH would be more than 110.
Yeah the AWD is nice, i'd actually like to get the 60ft under 1.8 :)
Sho Amo
SmkTyresntDrugs
Olney, Md
how much lower do you think youre gonna get it? also wanted to ask exactly what youve done to it.
darreli
Run'n from BPD
Michigan
11's ???
Not much really. A tune, CAI, a catback (last 2 really didn't make any more power) and meth inj from AlkyControl
