paging the SHOForum V8 Brain Trust!
venom
Rowboat Design
Toledo, OH
Oh by the by... I was just up in my shelves in the garage and discovered that I forgot that the last time I bought an ABS module (like November maybe) the yard had them for so cheap I bought both that they had.
If you still need one drop me a PM.
centrallaw
Tampa
I have been through five junkyard modules and they all eventually failed. Wiring inside module from connector to circuit board has been bad. Soldered the thread size wires, works for a year then failed again.
Still looking for a rebuilt module as these wires seem to be a culprit every time.
Rebuild anyone?
Casey.
venom
Rowboat Design
Toledo, OH
Rebuild anyone?
Casey.
I say blame Bosch for the POS design.... Just another feather in my "I can't stand Bosch" cap anyway...
venom
Rowboat Design
Toledo, OH
Not that uncommon from anecdotal posts over the years.
I searched "ABS module" in my gmail and got about 100 threads threads on the V8 listserv since 2005. Probably 25 of those were non list conversations.
Once you remove a bad one just touching the small wires from the terminals to the internals and they break right where they attach. About 2/3'rds of theses fine wires are swimming in a dielectric jelly so they can't really vibrate much or anything. Not all of them are however, and I don't think that jelly keeps them from breaking anyway but it probably helps with vibration some.
I still say blame Bosch...
One other thing of note for anyone in a rust belt state - removing the battery tray can go terribly wrong.... I have a recommended mod for it...
http://www.v8sho.com/SHO/Battery Tray Mounting Solution.htm
SuperHO
Mental Patient
St. Joe, MI
if these connections are indeed the culprit, is there anything to stop me from re-soldering the connections using something a tad more robust?
venom
Rowboat Design
Toledo, OH
These wires are super frail....
Half of them are covered in some di-electric Jelly that I can't imagine you could clean away gently enought o not do more harm.
And since they are sucha PITA to repalce I wouldn't want to install it, and fail even once.
