Dooleyville, this Saturday 10 AM till whenever
SHOmethewayhome
BAD ROLE MODEL
Saint Paul, Minnesota
whats with you knuckeheads and 5.slow convertibles?
Jesse was gonna GIVE me his old vert once upon a time, but then quickly talked me out of taking it.
i still need to thank him for that.
Shoaz
Studly dood
Scottsdale, AZ
There was consensus that that vert should be LeMons car. It just needs a few little things, like a drivetrain and stuff.
jessemachone
No Mo SHO
Scottsdale, AZ
so, when are you planning on swapping in an ecoboost?
I have carefully studdied the Dooley and have come to the conclusion that the Dooley is ecoboost compatible.
Off Road SHO
Moderator
Nick was sidetracked for a while with a little Ranger that he swapped an XR4Ti 2.3 into and I think he bought another Subaru WRX STi.
Tom
jessemachone
No Mo SHO
Scottsdale, AZ
I am thats why its got welded axle tubes, c-clip eliminators, 31 spline axles, and full spool.
Rear
Rear1
Chuck, are those double adjustable upper control arms I spy there? Are you running spherical bushings? I am in my lowers. Not as noisy as I thought they would be and worth every penny:)
Philthy
AMS Test Pilot
Peoria
I missed it because it was Tractor Day at Saguaro Ranch Park. But I missed that because I had the flu. I drug my butt out Sunday so my kids wouldn't miss Tractor Day then 3 of the 4 boys, my wife and I spent the next 6 days with the flu. It was splendid.
I have decided, I do not like the flu.
ChuckD
D, H, C
El Mirage, AZ
Yes they are. Not running spherical but i need now lowers. Where did you get them locally?
Off Road SHO
Moderator
Advanced Metal Sales at 27th Ave and Deer Valley Rd (hidden next to the Cracker Barrel Restaurant) has a lot of those.
Tom
jessemachone
No Mo SHO
Scottsdale, AZ
I am running the extreme duty lower control arms from maximum motorsports. They are in San Louis Obispo California. There are people on the web that will sell them a little cheaper MMX does. I have the ones set up for adjusting the ride height. They are built like a brick poophouse.
This is what I have: http://www.lastcallracing.com/mm-mmrlca-32.html
I didn't get them here but that is about what I paid.
They are cheaper if you don't get the adjustable ride height.
The reason I went with these and not the ones with just the heim joints at the end (like upr) is because these bushings are huge compared to what you get with a heim joint and they have steel around them where the other design just has the aluminum around the spherical part.
I would hate to have a heim joint failure while throwing a ton of power at it.
I am not making a ton of power now but my goal is to install a 408 LSX. I only want to buy suspension parts once so that is why i went with what I did.
P.S. the bushings in these arms are replaceable. They are held in with a circlip and can be replaced eisly if need be.
ChuckD
D, H, C
El Mirage, AZ
I got Lakewood lowers. Lakewood 90/10s and 50/50 shocks. HPM caster camber plates, UPR coil over kit. MM tubular k member and a-arms. The car is jumbled with used parts that were never installed. I bet I have saved more than half just keeping my eye out for deals.
Lcasho92
