95 sho in need
SHOYa MaMa
ri
i have a 95 5 speed sho i just put a new mass air flow sensor but its acting up. it was used out of another 95 sho. the check engine light went off but i took it for a drive i tried to get on it and it basically shuts off like the engine has no gas. it sputters and and slows down. ill unplug it it runs fine but light is on so wht can i do to fix this prob
NP SHO
Rice Killaaa
Windsor, New York
This might be a stupid question, but if it's used out of another car have you tried cleaning the sensor? Are you sure that it was a good sensor out of the donor car?
frosho
WOLFMAN
Tyngsboro, MA
SHOYa MaMa
ri
it was a good sensor and yes i cleaned it thats why I'm asking if this sounds like a common prob. with sensors my sho has been sitting for a while i bought a car without the sensor and air box i put one in and the sensor worked good at first but after running for about 15 min. so idk.
Yes, clean the maf. Remove the sensor from the housing and spray the filaments with MAF sensor cleaner. Reinstall and report back (in the correct forum, please)
Edit...you beat my reply...anyway, if you cleaned it...take it out of the housing and inspect the filaments with a maggot frying glass. I'll bet you see a bunch of dirt on the filaments or a broken filament.
gmail
Well-Known Member
sunbury pa
agreed i would inspect it and also make sure its the right MAF you never know it might not be a stocker...
also if all that passes check the wiring...
weird you say it runs fine with it unplugged i could never get that with them unplugged, granted it will run but cough and spudder being that when the maf signal is lost it goes stupid rich mode.
hows the rest of the 60k?
NP SHO
Rice Killaaa
Windsor, New York
What did you use to clean it? Was it MAF cleaner or something else?
Yes, clean the maf. Remove the sensor from the housing and spray the filaments with MAF sensor cleaner. take it out of the housing and inspect the filaments with a maggot frying glass. I'll bet you see a bunch of dirt on the filaments or a broken filament.
This is a very good point. Make sure you remove the sensor from the housing and spray the crap out of it, let it dry, then reinstall.
Love the maggot frying glass. lol. Seriously though, make sure you inspect the sensor closely. Are you running a new or at least clean air filter? If you're not using a good filter it may just be dirt/dust coming through or from filter crapping up the sensor again. Just a suggestion.
SHOYa MaMa
ri
ok wrong section im new sorry i would of got new cleaner today but weather is horrible for any work at all to be done. this sho is new to me i used a buddies generic sensor cleaner. MAF sensor cleaner is wht i need love the links on the code pulling link very helpful.
NP SHO
Rice Killaaa
Windsor, New York
Yeah, definitely use MAF sensor cleaner. The suggestion about the magnifying glass is good too. It'll let you see some of the crap on there that you might normally miss. Let us know how you make out.
Also on a side note - Not trying to pick on you or anything, but try to work on the grammar in your posts. Some people will really flame you for that on here. You will find that you will get more help from more people if your posts are easier to read. Like I said, not trying to be a dick. Just trying to help you out.
gmail
Well-Known Member
sunbury pa
also be careful to use maf cleaner only because you can **** a maf sensor quicker then you would expect with brake cleaner or something of the like
